Circle Cutting Jig ( for the bandsaw) #3: Recent modifications
Blog entry by BritBoxmaker posted 02-06-2011 09:50 PM 2970 reads 3 times favorited 5 comments Add to Favorites Watch
« Part 2: Of slidey things Part 3 of Circle Cutting Jig ( for the bandsaw) series no next part
One obvious failing on the jig was pointed out by Trevor (tdv) in that with the sliding table away from the right hand side of the blade the workpiece is unsupported on this side and could suffer chipout. Good point so
Version 2.1 -TDV modification
A small piece of beech is fixed to the jaw of the left fixed table to act as a sacrificial zero clearance jaw. The corresponding cutout is made in the sliding table jaw to accommodate this and allow the jaw to still close up.
As its screwed into place this is replaceable when worn.
Version 2.2 – N6DSW modification
Also from Dave (N6DSW) comes the idea for an index marker for the guide pin.
I use this against a hand held ruler but you could also attach a scale to the fixed runner opposite this. I need time to find a suitably stout scale and route it in.
Any more suggestions are warmly welcomed and yes you will get a mention, as above
As I mentioned in the comments section of the last part of the blog Please DO clamp the jig down tho the bandsaw table for safety reasons! (my mitre slot rail is just so tight I’ve not done this yet, naughty me).
Be seeing you.
5 comments so far
TopamaxSurvivor
18292 posts in 3704 days
#1 posted 02-06-2011 10:09 PM
Good ideas, thx
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3135 days
#2 posted 02-06-2011 11:24 PM
Hey Martyn, I’m switching my shop over to metrics. Do you want an Imperial yard stick? lol I’m sorry, I just could not resist. This is a beautiful jig. and the tutorial is awesome. Thank you for taking the time and effort to show this to us. Rand
View BertFlores58's profile
BertFlores58
1698 posts in 2950 days
#3 posted 02-07-2011 03:34 AM
Hi Martyn,
Suggest that on the center pin, bearing or bush should be fitted. The wear in tear will be present and it will create much error. I used the EBONY bush or the MOLAVE (not common in your place) as they have oil in them. The best wooden bush is Lignum vitae..
I am eager and wants to design circular pattern this time. I will make one of this for my portable router. Thanks for the blog.
-- Bert
View SPalm's profile
SPalm
5320 posts in 3910 days
#4 posted 02-07-2011 03:32 PM
I like the zero clearance modification. I was wondering about that. I was envisioning a sliding one underneath the sliding table. Yours seems much simpler. Nice mod.
Steve
-- -- I'm no rocket surgeon
View mafe's profile
mafe
11732 posts in 3118 days
#5 posted 02-07-2011 06:35 PM
Really a wonderful jig, a well done blog and some cool details.
Thank you Martyn for taking your time to share this,
Best thoughts,
Mads
