Quick Tip - Extending knife blade life
Blog entry by BritBoxmaker posted 958 days ago 1319 reads 2 times favorited 13 comments Add to Favorites Watch
I use an Xacto Knife for veneer and fine cutting. The tip of the replacement blade wears out all too quickly
This is the problem drawn for clarity
The top two drawings show a side and top view of a new blade. The middle two show a worn blade (exaggerated). The fine point is now a larger flat (or more accurately rounded) point and will also be burred over slightly (not shown) making it even duller. What I do to restore the point is grind the back of the blade off, at a slight angle, on an oilstone, to past the blunt material (bottom two drawings). This can be done several times and whilst the attacking angle of the tip of the blade is a little broader at least you have a freshly sharp tip to work with.
Be seeing you.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
13 comments so far
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1288 days
#1 posted 958 days ago
great tip Martyn
I had scraped hundreds of theese kind of blades over the years and they ain´t cheap
when you use them that fast :-( it seems to me it can be done 5 to 6 times before trashing them now
thank´s for sharing it :-)
take care
Dennis
View Wes Giesbrecht's profile
Wes Giesbrecht
153 posts in 984 days
#2 posted 958 days ago
Why didn’t I think of that? :-)
-- Wes Giesbrecht http://www.wesgiesbrecht.com/index.htm
View degoose's profile
degoose
6598 posts in 1527 days
#3 posted 958 days ago
Now there is a tip for you…so simple and yet so very effective.
12081 posts in 1514 days
#4 posted 958 days ago
to cool
great tip
thanks
View SPalm's profile
SPalm
4120 posts in 2054 days
#5 posted 958 days ago
Well how about that. Simple enough.
I like it,
Steve
-- -- I'm no rocket surgeon
View mafe's profile
mafe
8057 posts in 1262 days
#6 posted 958 days ago
exelent idea, so simple.
Less is more again!
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
View BertFlores58's profile
BertFlores58
1539 posts in 1095 days
#7 posted 958 days ago
That is quick sharpening tip. How thick is the blade? Thanks for posting.
-- Bert
View Flemming's profile
Flemming
417 posts in 1069 days
#8 posted 958 days ago
great thinking martyn!
thanks for the info :)
-- Flemming. It's only a mistake if you can't fix it.
TopamaxSurvivor
13194 posts in 1848 days
#9 posted 958 days ago
Great idea!! I usually use more of the blade but if I get to inlaying a lot, that will sdave some long Yankee Green!
View BigTiny's profile
BigTiny
1653 posts in 1061 days
#10 posted 957 days ago
This is an old idea but a good one. I first saw it in an old book on marquetry and have used it for a while now.
In answer to the thickness of X0acto blades, I think they’re about 1/32nd inch or so.
For veneer cutting, you can get at least a half dozen resharpenings out of a blade. Just extend the rear bevel a bit more each time.
I never thought to post this here. I should have, but at least someone did, and that’s the important part.
-- The nicer the nice, the higher the price!
#11 posted 957 days ago
I have been sharpeniing Xacto blades and the similar blades used for cutting matte boards for picture framing.
I also have found the ‘snap off’ box cutters to be sharp enough to use for careful cutting and can be similarly resharpened for extended working life.
ddwwb
-- The best things in life aren't THINGS.
View swirt's profile
swirt
1864 posts in 1144 days
#12 posted 957 days ago
Very clever and so simple. Thanks for taking the time on the diagram. It instantly makes it clear.
View Armand's profile
Armand
189 posts in 1083 days
#13 posted 955 days ago
You have a beautiful mind Martyn.
-- My Master is Mankind's Greatest Carpenter.
