Clipboard #2: Old Friends
Blog entry by BritBoxmaker posted 09-30-2010 11:57 AM 2656 reads 10 times favorited 22 comments Add to Favorites Watch
« Part 1: WHERE'S ME CLIPBOARD! Part 2 of Clipboard series Part 3: Tumbling Dice (blocks) »
Before I start. All the pictures in this blog (and all my blogs for that matter) are left handed. I suggest all you righties out there copy the pics and flip them, as I do with your’s.
Continuing the ‘atomic’ theme I now introduce you to Manhattan
This is the cutting board I use for parquetry. Made in 2001 and still going strong. Its basically like a bench hook, as used for hand sawing, with a couple of differences. Its made from a piece of MDF 350×300 x 6mm with a couple of strips of 12mm Birch ply attached(one at top back, the other at front bottom). To extend knife blade life the face of the MDF can be covered with self adhesive vinyl tile.
The piece of 3mm Hardboard (Masonite, could also be vinyl tile) attached at the right side is a 60°/30° right angle triangle which is a special mod’ (modification) to this jig to allow easy cutting of diamonds for Louis Cube patterns.
In addition there are two identical spacers used to set the piece width
Before I start cutting there’s one thing to attend to which veneers and people with long hair have in common. Split ends. I tape mine with veneer tape (very thin paper tape with a gum backing, which you have to wet, like old postage stamps), ‘because they’re worth it!’
Time for cutting the diamonds for the pattern. First I cut all the pattern veneers into strips (this time 20mm wide). Butt the veneer edge up to the back ply strip. Knife cut is the side of the ruler closest the ply strip.
The handy spacers making sure all the strips are exactly the same width. Once I’ve cut all the veneer into strips I move on to the second operation which is to cut the diamonds. Aligning a strip to the sloped side of the triangle guide I first advance it until the square end is all the way under the ruler and trim off the triangle of excess. Then I butt the sloped end of the veneer up to the ply and cut off a diamond.
I’ve used the same spacers for a perfect diamond.
When the strip becomes too short to reliably keep the 60° angle (by alignment to the triangle)
just move it over and bring in the next strip to align it against
After a couple of hours and aching muscles in the lower arms I’ve cut all the diamonds. Time for tea and custard creams ( biscuit of choice for me ).
Be seeing you.
22 comments so far
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3030 days
#1 posted 09-30-2010 12:02 PM
Here is a pic of the first cube
View degoose's profile
degoose
7233 posts in 3349 days
#2 posted 09-30-2010 12:05 PM
Should I take up the fine are of veneering I will keep Manhattan in mind..nice bit of kit…
Looking forward to more atomic moments…
I have quite a bit of veneer and even a vacuum bag setup… one day…maybe..
View littlecope's profile
littlecope
3071 posts in 3496 days
#3 posted 09-30-2010 12:42 PM
Positively Nuclear Thinking, Martyn…
Looking forward to this one-of-a-kind Clipboard!!
View Sheila Landry (scrollgirl)'s profile
9228 posts in 2914 days
#4 posted 09-30-2010 12:49 PM
Now this is one I may have to try soon! I love seeing this! It is a wonderful way to get such perfect and uniform pieces. Thanks so much for showing us and sharing it with us.
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View Triumph1's profile
Triumph1
890 posts in 3073 days
#5 posted 09-30-2010 01:02 PM
Ever think of going to a high school/university and teaching a woods class? You are one hell of a teacher. I am thouroughly enjoying your first two installments!
-- Jeff , Wisconsin Please...can I stay in the basement a little longer, please!
View SPalm's profile
SPalm
5320 posts in 3876 days
#6 posted 09-30-2010 02:04 PM
Sweet.
Very nice, and simple. I like it.
You seem to do a lot of pre-thinking to your projects. I can really appreciate that. A nice way to spend idle moments in life.
Always watching,
Steve
-- -- I'm no rocket surgeon
View Cozmo35's profile
Cozmo35
2200 posts in 3030 days
#7 posted 09-30-2010 03:04 PM
You may get promoted with such a nice clipboard. :-)
You always do great work Martyn!
-- If you don't work, you don't eat!.....Garland, TX
View lumberdustjohn's profile
lumberdustjohn
1263 posts in 3161 days
#8 posted 09-30-2010 03:21 PM
I sit quietly in the back of the room.
Thanks for sharing
-- Safety first because someone needs you.
View mpounders's profile
mpounders
875 posts in 2889 days
#9 posted 09-30-2010 05:33 PM
Wow! I have always thought veneering was beyond my humble skills, but your illustrations have provided some valuable knowledge. I have always admired fine veneer work, especially your fantastic pieces, but now I might have to try some. Maybe my own clipboard! Thanks mucho.
-- Mike P., Arkansas, http://mikepounders.weebly.com
BritBoxmaker
#10 posted 09-30-2010 06:10 PM
Thanks Mike, have fun.
BritBoxmaker
#11 posted 09-30-2010 06:19 PM
Steve, I like to plan ahead as much as possible, thinking my way out of what pitfalls I can predict. That way the problems that always do occur are easier to cope with and fewer in number. I wonder what the cock-up is going to be on this one?
Jeff, I think I’ll stick with correspondance work here at LJ’s. I find face to face teaching a little nerve wracking.
Sheila, give it a go it really is easy. Just make sure not to leave too many gaps. I’m famous for that.
Mike (Coz), if I get promoted I won’t need the clipboard anymore. Dilema!
Mike (littlecope) and Larry , lol
Part 3 will show the pattern build-up and features ‘Little Boy’
View RogerBean's profile
RogerBean
1605 posts in 2948 days
#12 posted 09-30-2010 06:22 PM
Martyn,
Many thanks for this blog. I am learning from you, and I appreciate your sharing nature. I’ve been pondering how parquetry can be used in my own work, and have yet to settle on just how to use it, but your work is hugely instructive. I always look forward to your posts, as they are inevitably insightful and helpful. My compliments. Keep on boxing!
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
BritBoxmaker
#13 posted 09-30-2010 06:40 PM
Thanks Roger. Nice to know the ‘how to’ before the ‘what’. I’m afraid I usually do it the other way around but then I do like a challenge. I am a great admirer of your work and look forward to seeing what you might do with this.
View Ampeater's profile
Ampeater
440 posts in 3741 days
#14 posted 09-30-2010 11:58 PM
That is a great cutting jig. I have been working on a serving tray that has a base made up of 175 pieces, mostly cut at 60*. They were all 3/8” thick. I had a difficult time getting the cuts accurate. I plan to adapt your technique to my crosscut sled. It will make my next serving tray much easier to build.
Thanks for posting this.
-- "A goal without a plan is a wish."
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3109 days
#15 posted 10-01-2010 02:25 AM
great little jiig you have there :-)
thank´s for thaking you time and sharing so much
nearly always a pleassurre to learn from you,have you ever thought on how nervewrecking
it is to bee a student in your classroom with that shittystick in the corner Proffessor…. :—O
have a great safe day
Dennis
showing 1 through 15 of 22 comments
