Zero Clearence with Riving Knife
Blog entry by BritBoxmaker posted 976 days ago 1147 reads 0 times favorited 14 comments Add to Favorites Watch
Hello all. I see many posts of Zero Clearence inserts for table saws and these are really good. They save tearout and add safety to your saw. However if, like me, you have a table saw like this one…
the blade gulley is too narrow for an insert, its about 12mm (1/2”) wide and chewed up the one I tried making for it. Simple solution is to use a sheet of MDF, I suggest 9mm (3/8”) minimum. You set your fence distance up to the width you want to rip, with the fence all the way from front to the back of the table. Set your blade depth to the thickness of the timer (lumber) you are going to rip plus the thickness of the board plus the depth of the teeth. Place the board against the fence with the end nearest you in contact with the table (with a clamp for a stop if you are worried about it sliding back toward you) and gently lower the back end of the board onto the moving saw blade. I stress WATCH OUT FOR THE PLACEMENT OF YOUR FINGERS RELATIVE TO THE BLADE THROUGHTOUT THIS OPERATION. I will NOT be held responsible for missing digits.
Now we come to the real pain for people who use thin blades, like me. I use a 1.8mm (5/64”) blade to minimise wastage due to saw cut. It also requires less power. The riving knife on my saw is 3mm (1/8”) and so useless with a 1.8mm blade..
If you cut 25mm (1”) past about where the blade is coming out of your zero clearence board you leave room for a shop made riving knife so
This one is Ebony (from my Ebony bits box) but any hardwood will do. Its cut to the same width as the saw blade and rounded slightly on the leading edge (with 120 grit sandpaper) to stop any snags and is glued into the slot using super glue (to stop it dissappearing into the blade gulley). Finally set up to rip, the board is secured to the table, at the rear with a clamp and the fence re set to the mid point of the blade (to avoid snatching on the upward moving rear of the blade).
Happy ripping.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
14 comments so far
View BritBoxmaker's profile
BritBoxmaker
4003 posts in 1202 days
#1 posted 976 days ago
ps I’m not trying to insult anyone’s intelligence here. Just pass on something that might be useful.
View PurpLev's profile
PurpLev
7729 posts in 1814 days
#2 posted 976 days ago
looks good, but for safety issues,I’d like to have the area in front of the blade as large as possible. you can also use a sheet of masonite (hardboard) and rip it until it covers the table while the fence is positioned for your additional rip cuts – install the splitter, and you have a full sleek surface to rip on top of.
BritBoxmaker
#3 posted 976 days ago
Good point, Sharon. Covering the full depth of the table is advisable.
Masonite (hardboard) is generally only available in 3mm (1/8”) sheets in the UK (far too thin to attach a riving knife or splitter into and expect it to stand upright for long), hence the reference to using, thicker, MDF.
PurpLev
#4 posted 976 days ago
agreed. thicker material would make it easier to wedge something in.
View William's profile
William
7056 posts in 1008 days
#5 posted 976 days ago
I cut various table inserts for my saw out of MDF. I have a zero clearance, dado, etc. I cut them to fit into the hole of the stock insert with a scroll saw. Just trace the stock insert onto the wood and cut. Sand as needed to fit. Then I planed it down to be flush with the table.
Another issue is lowering the insert over the blade to cut the slot for said blade. I use to do it this way. Then I had a very close call and was scared to do it that way. It takes a lot to rattle me, but this scared the snot out of me. Now, I let my blade all the way down into the table. Put the insert in place. Turn the saw on. Use a scrap piece of wood to hold the insert down so it doesn’t try to rise upwards. Then turn the saw on and slowly raise it up though the insert. I’ve never had any problems doing it this way and feel it is much safer.
PurpLev
#6 posted 976 days ago
William – I agree with you on making ZCI for western saws – but if you’ll notice, Martyns saw doesn’t have a factory insert that can be replaced, which is why he suggested the topper-zero clearance concept.
William
#7 posted 976 days ago
I forgot to mention the riving knife. This may not work on all saws. Mine is a Rigid 3650. Making the insert the way I do on my saw, it is still thick enough (about 1/2”) to put in a riving knife the way you showed. I also have one made that way. I have one thin blade I use when very seldom, but when I do, I had to make a riving knife like you because my stock knife was too thick. Actually, the thickness of my riving knife is exactly why I don’t care for thin blades much. I like my stock knife with the anti-kickback pawls on it. Also, my safety sheild is attached to the stock riving knife.
William
#8 posted 976 days ago
I’m sorry. I thought that round piece lifted out like my factory insert. If it doesn’t, then I can see why you’d do it as he’s described. If possible, I’d still suggest raising the running blade up instead of lowering the wood over a moving blades for safery reasons, if this is possible.
PurpLev
#9 posted 976 days ago
I’ll second the raising of the blade as well. although since you are partially ripping the (somewhat) thick MDF, and wedging a splitter behind the blade – I don’t even see a need to lower the panel ,nor raise the blade. Just set the blade to rip through the MDF but instead of a full through rip, stop in the middle. stop saw, wedge splitter. done deal.
BritBoxmaker
#10 posted 976 days ago
I agree with you both, there are many ways to acheive the end result.
This method works for me.
PurpLev
#11 posted 976 days ago
no offense Martyn, was just thinking out loud. :)
BritBoxmaker
#12 posted 976 days ago
No offense taken, Sharon. Your points are valid and present people with alternate methods which they may find more acceptable. Just being factual.
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1281 days
#13 posted 976 days ago
thank´s for the tip Martyn
Dennis
View mafe's profile
mafe
8055 posts in 1255 days
#14 posted 976 days ago
Hi Martyn,
Thats clever, and I’m happy not insulted, did not know this little trick.
I can use this tip on my tablesaw, and was annoyed I could not make a zero clearens for it.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
