Impossible II
Blog entry by BritBoxmaker posted 08-03-2010 06:39 PM 9198 reads 47 times favorited 23 comments Add to Favorites Watch
Hi everyone. Here is the method for making the Impossible II. Before we start I didn’t take any photos during the build for this one. I needed to concentrate full time on it and taking pics can be distracting. The CAD drawings provided here should do the job . I’ve seen Steve (spalm) use this sort of thing to great effect. I’m not giving exact sizes, you can scale things off of the pics. This will give you the angles too, mostly 60°.
First the complete pattern
You need to find the minimum repeatable unit, which in this case is a hexagon
This is made up of six triangles
Each of these triangles is made up of five pieces
The four woods I used were Pau Amarello, Padauk, Purpleheart and Ebony
So for the whole hexagon you need six of the large shapes (of each of the first three woods), two of the mid sized shapes (of each of the first three woods) and six small Ebony triangles.
To make an end grain pattern you make up sticks with the above outlines, long enough to cut into slices, when the hexagon is finished, to make up your overall pattern.
I first glued up the pieces for each of the six triangles using PVA and masking tape to bind them, cleaned them up on the drum sander and then stuck them together (in the correct order) again with PVA and tape.
When this assembly was dry I removed the tape and sliced the hexagonal stick into slices, arranged and glued them to a backboard and trimmed it with Ebony.
Thats it in a nutshell. Have fun.
23 comments so far
View Cozmo35's profile
Cozmo35
2200 posts in 3065 days
#1 posted 08-03-2010 07:05 PM
Martyn, This is an amazing piece, but you make it sound easy with your description. I am in awe of your talent! THANK YOU FOR POSTING IT!!
-- If you don't work, you don't eat!.....Garland, TX
View kevinw's profile
kevinw
195 posts in 3768 days
#2 posted 08-03-2010 07:19 PM
How did you cut the pieces in an accurate and repeatable enough fashion?
-- Kevin, Blue Springs, MO
View miles125's profile
miles125
2180 posts in 4034 days
#3 posted 08-03-2010 07:24 PM
Very cool. Looks like one of those magic eye pictures.
-- "The way to make a small fortune in woodworking- start with a large one"
View lumberdustjohn's profile
lumberdustjohn
1263 posts in 3195 days
#4 posted 08-03-2010 07:32 PM
Thanks for the posting.
This is not on my to do list yet.
I will relax and enjoy yours.
-- Safety first because someone needs you.
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3065 days
#5 posted 08-03-2010 08:06 PM
Kevin, I cut them on a tablesaw with the blade set to 60°. Oh and a fence to cut against. Distances set using the micro-adjuster I posted recently. Plus I cut all of one size in one go without a break and no adjustment of the fence between cuts.
View BertFlores58's profile
BertFlores58
1698 posts in 2951 days
#6 posted 08-03-2010 09:29 PM
Martyn, you are so precise in doing all the pieces in systematic way. The smallest ones to do is the ebony and the other which I think was done gluing the component board then ripped it to a prismatic triangle, crosscut to thickness. The trapezoid component of the triangle is ripped then crosscut. Hard to guess, and much harder to do it. Thanks for posting.
-- Bert
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3144 days
#7 posted 08-03-2010 10:34 PM
Martyn
thank´s for posting
one more question
I know you played around with endgrain but cuoldn´t it have been made
the otherway and obtained the same feeling in the finished piece
and wuoldn´t it have been easyer to make the cuts and glue up
Dennis
View moshel's profile
moshel
865 posts in 3713 days
#8 posted 08-03-2010 10:53 PM
that takes some precision cuts to get without noticeable gaps in the glueup….
as I am not as precise i would at least glue the inner pieces of wood and then rip them to triangles. would save me on ripping very small strips that i don’t really like. will also make the glueup easier (but add a stage). amazinf work and thanks for the blog!!!!
-- The woods are lovely, dark and deep, but I have promises to keep...
View tyskkvinna's profile
tyskkvinna
1310 posts in 3015 days
#9 posted 08-03-2010 11:28 PM
Geometry and I are pretty good buddies, but this makes my head hurt just watching …
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View SPalm's profile
SPalm
5320 posts in 3911 days
#10 posted 08-04-2010 12:03 AM
Martyn, This is an amazing design. It really came out well. I would not have thought that such a complicated pattern would look so fantastic.
It also seems like doing it in endgrain was the way to go. That would have been a lot of small pieces if done with one glue-up in face grain.
Good job Sir,
Steve
-- -- I'm no rocket surgeon
View Chris Cunanan's profile
Chris Cunanan
339 posts in 3509 days
#11 posted 08-04-2010 03:11 AM
i would think it would be easier to make a couple glue-ups of longer stock, then just crosscut the triangles off ‘n piece together individually…i’m just thinking out loud, but please someone correct me if there would be an easier way? i’d love to try this, i could imagine it so tricky looking ‘n pleasing to the eyes if done right in the end.
View Mary Anne's profile
Mary Anne
1058 posts in 3237 days
#12 posted 08-04-2010 04:20 AM
You have outdone even yourself on this one, Martyn.
It’s great the way you break these down to the simplest (?) common piece and turn it into something extraordinary.
View zlatanv's profile
zlatanv
691 posts in 3263 days
#13 posted 08-04-2010 07:19 PM
Mind numbing!
-- Z, Rockwall, TX
BritBoxmaker
#14 posted 08-04-2010 11:10 PM
Steve, Experience tells me that reduction and endgrain in combination are the only way I’d go for something this complicated, these days.
Thanks all for your attention and interest. I need a rest.
View Steph78's profile
Steph78
68 posts in 2874 days
#15 posted 08-16-2010 12:53 AM
Pure genius! That is just amazing! Thanks for posting it!
-- Steph, Phoenix
showing 1 through 15 of 23 comments
