The Impossible #6: Its high time, Cymbaline
Blog entry by BritBoxmaker posted 06-17-2010 06:16 PM 4270 reads 10 times favorited 31 comments Add to Favorites Watch
« Part 5: Fearless Part 6 of The Impossible series no next part
You are not going to believe how simple this glue-up is going to be. Some of you will not believe it will work. Others, possibly some of the cutting board purists, will say I’m cheating. Frankly Scarlet I don’t give a damn (name that movie). This is a box top and all its joints don’t have to be impervious to water, like a cutting board. I will flood the top of the pattern with a clear epoxy finish ultimately, anyhow.
These are the players in this little drama. Left, the pattern held tightly in a six sided frame (more of which in a moment.Top left, vertically grain orientated (relative to the Ebony grain direction in the pattern) 1.5mm Birch aeroply. Top right, horizontally grain orientated 1.5mm Birch aeroply. Bottom left 6mm MDF backing board. Bottom right, 6mm MDF top board, slightly smaller than the pattern being clamped.
The pattern frame
consists of six pieces all slightly shorter than the side length of the pattern. Each with a slot at the rear to accept a long string, used to pull them and therefore the pattern evenly together. Tied off when tightened.
Clamped
withe twelve clamps. In order from bottom to top. Backing board, horizontal aeroply (top glued), vertical aeroply (top glued), pattern in frame, top board (holding the pattern pieces flat). Its in there with the glue setting as I blog. Oh and yes I’m aware that I will have to cut the pattern frame off afterwards. Will it work? Should do, don’t know. Its the first time I’ve done it like this. We’ll see.
31 comments so far
View Sheila Landry (scrollgirl)'s profile
9228 posts in 2915 days
#1 posted 06-17-2010 06:22 PM
It really looks cool. (I can hear the drum roll in the background!) You’ve got our full attention, Martyn . . . I am sure waiting for the glue to dry is much like watching the pot of water come to a boil in instances like this. The anticipation is thrilling!
I can’t wait to see the unveiling! Something I am so looking forward to! Great job!
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
117090 posts in 3572 days
#2 posted 06-17-2010 06:22 PM
Great clamping technique along with a out of this world great board.
View stefang's profile
stefang
15881 posts in 3329 days
#3 posted 06-17-2010 06:40 PM
Looking great Martyn. Now that it’s almost finished, I’m beginning to wonder what you will be coming up with next. Especially since you have now set the bar so high. A challenging thought, huh?
View spaids's profile
spaids
699 posts in 3688 days
#4 posted 06-17-2010 06:52 PM
HA! You did it! WOW
-- Wipe the blood stains from your blade before coming in.--
View majeagle1's profile
majeagle1
1426 posts in 3491 days
#5 posted 06-17-2010 07:03 PM
Looooooooooooookin good ! Love your techniques and this is going to be one beautiful box.
Of course, you are going to use the same pattern for the box sides and bottom….. right !!?? LOL
Can’t wait for the conclusion to this fine drama.
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
View SPalm's profile
SPalm
5320 posts in 3877 days
#6 posted 06-17-2010 07:23 PM
Never seen THAT before. I have seen the string technique, but not used with a sandwich. I trust you Man.
Those clamps sure look purty.
Your Student,
Steve
-- -- I'm no rocket surgeon
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3281 days
#7 posted 06-17-2010 08:03 PM
Great series!
Thanks for taking the time to share.
Kent
-- http://shepherdtoolandsupply.com/
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3031 days
#8 posted 06-17-2010 08:24 PM
Here it is trimmed. Rough sanded with 150 grit nd sealed. A little gappy in places but it proves a point. Sometimes the impossible is acheivable.
Thats it for this blog. The pattern will probably be incorporated in a box in the near future. I’ll post that when its complete. The box making stuff is going to be nothing new. Hope you enjoyed this. Go on have a play. You must be able to do it tighter than this or different. You choose.
View Mary Anne's profile
Mary Anne
1058 posts in 3203 days
#9 posted 06-17-2010 08:37 PM
Impossible! :) Your creativity is boundless.
If I had that sitting in my house, I would probably get even less done than I do now. It is fantastic to stare at in pictures… I can only imagine to hold it in my hands.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3110 days
#10 posted 06-17-2010 09:54 PM
interressting mix of tecnic # Speed
it´s deffently a classroom we have to follow closely
or ells…....wooood be difficult to read up before excamination
thank´s once more Martyn to have used your valueble time
to knock some wisdom in to empty heads
Dennis
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3102 days
#11 posted 06-17-2010 09:59 PM
Wow! Martyn, I think you need a holiday at the beach to clear your head after this. Awesome! Rand
View Cozmo35's profile
Cozmo35
2200 posts in 3031 days
#12 posted 06-18-2010 12:08 AM
Martyn, That is absolutely AMAZING! I am in awe! As I stated before,...”You are THE MASTER!”
-- If you don't work, you don't eat!.....Garland, TX
View CampD's profile
CampD
1658 posts in 3481 days
#13 posted 06-18-2010 12:11 AM
Wow, that has some depth to it.
Nice!
-- Doug...
View littlecope's profile
littlecope
3071 posts in 3497 days
#14 posted 06-18-2010 01:15 AM
Great Series, Martyn!!
My hat is off to you, Sir!! (because I’m still scratching my head in wonder!!) :)
View Bearpie's profile
Bearpie
2601 posts in 3013 days
#15 posted 06-18-2010 01:41 AM
Martyn, You exceeded my expectations by far. Superb work and I thank you for doing this blog and showing us how the Master Works.
Everyone all together now: 3 cheers for Martyn!
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
showing 1 through 15 of 31 comments
