The Impossible #5: Fearless
Blog entry by BritBoxmaker posted 06-15-2010 07:12 PM 6861 reads 7 times favorited 44 comments Add to Favorites Watch
« Part 4: One of these days (I'm going to cut you into little pieces) Part 5 of The Impossible series Part 6: Its high time, Cymbaline »
Today I sanded, I sliced, I diced and I shaped. I was not at home to Mr. Cockup. Today I’m fierce and to the strains of ‘Fearless’ off, Pink Floyd’s Meddle off I went. All this took just two hours..
First I sanded all the slices to 6.93mm
then I glued them together (superglue, most precise and quickest)
Then I shaped the triagle ends on the disc sander
The I fulfilled my promise of yesterday and chopped them into little pieces
Back to the tablesaw with some ebony and my 60° jig I cut some triangles
So now I have all the jigsaw pieces
and so a quick tryout. The edges aren’t cleaned up yet so I’m not overly worried about the fit at this stage. This basically is what it will look like.
Just one small section to tantalise. The grain direction works. The sizes are right. All that remains is clean up of the pieces and glue up.
44 comments so far
View David Craig's profile
David Craig
2137 posts in 3012 days
#1 posted 06-15-2010 07:16 PM
Fearless is a great title. What an intense design. Thanks for keeping up with the post.
David
View SPalm's profile
SPalm
5315 posts in 3785 days
#2 posted 06-15-2010 07:22 PM
That is amazingly wacko. You appear to be over the hill.
But Yikes, the clean up and glue up. I wonder why they are both ‘up’ ?
Steve
-- -- I'm no rocket surgeon
View Will Stokes's profile
Will Stokes
267 posts in 3257 days
#3 posted 06-15-2010 07:28 PM
Eagerly awaiting part 6! :-) By the way, ebony was a great choice. It really lets the foreground “pop” if you know what I mean. I suspect design will really work well in the end…
View Mary Anne's profile
Mary Anne
1058 posts in 3111 days
#4 posted 06-15-2010 07:29 PM
This is going to be incredibly eye-popping! My favorite project of yours is still the kaleidoscope boxes, but I think this one is going to be a contender.
View majeagle1's profile
majeagle1
1426 posts in 3399 days
#5 posted 06-15-2010 07:31 PM
Fantastic Martyn, love it already…........
Edjumacate me if you would please: You said you used “super glue” to glue these small pieces together.
I am assuming you are referring to “CA” glue, if so, is it thin or thick?
You are going to use this as a boxtop: is this kind of glue strong enough? will there be a backing at all on this?
Sorry for all the ? but I have thought of using CA glue for some small pieces, but didn’t know if it would be strong enough…....
What are your thoughts…...
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
View jm82435's profile
jm82435
1285 posts in 3645 days
#6 posted 06-15-2010 07:36 PM
Looks like you are approaching the home stretch. It is looking great.
-- A thing of beauty is a joy forever...
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 2939 days
#7 posted 06-15-2010 07:41 PM
Gene
The superglue mentioned is a thick (high viscosity) type.
The pattern is intended to be used as a box top and there may be a backing to it so the physical strength of the superglue joint would not be an issue.
If I glue-up the pattern from these pieces with PVA this would also not be an issue as the the superlue joint would be surrounded by PVA joints, significantly stronger.
I welcome questions so this is not a problem either.
View Cozmo35's profile
Cozmo35
2200 posts in 2939 days
#8 posted 06-15-2010 07:42 PM
Martyn, I would have never believed it unless I had seen it with my own eyes! Only you could pull this off! UNBELIEVEABLE! You are THE master!!
-- If you don't work, you don't eat!.....Garland, TX
View spaids's profile
spaids
699 posts in 3596 days
#9 posted 06-15-2010 08:31 PM
Wow man. And you figure out how to do it with so few piece types. I can’t wait to see this finished. I get confused just trying to think about it. Great job.
-- Wipe the blood stains from your blade before coming in.--
16272 posts in 4121 days
#10 posted 06-15-2010 08:35 PM
Sure, it looks easy when YOU do it! :-)
View Woodcanuck's profile
Woodcanuck
128 posts in 2903 days
#11 posted 06-15-2010 08:44 PM
That’s awesome…I wonder if piping in some Pink Floyd into my workshop will help me improve my skills.
-- Ian - Life's a game, if you don't play, you can't win.
View Bearpie's profile
Bearpie
2601 posts in 2921 days
#12 posted 06-15-2010 08:48 PM
This is beautiful! Thanks for continuing.
Erwin
-- Erwin, Jacksonville, FL
View Tony Strupulis's profile
Tony Strupulis
260 posts in 3026 days
#13 posted 06-15-2010 08:53 PM
I hope you get this project done before you get to “Echoes”. 23 minutes? That will really slow down your production rate!
-- Tony - http://ravensedgetoolworks.com
BritBoxmaker
#14 posted 06-15-2010 09:03 PM
Stop press! Still no clean-up of the pieces or glue but I have enough pieces for 250mm x 130mm. This is a dry run!
View longgone's profile
longgone
5688 posts in 3211 days
#15 posted 06-15-2010 09:04 PM
Your creative imagination goes a long way.
showing 1 through 15 of 44 comments
