Snakes Pattern in Solid Wood #3: Preparation or Going for the Big One.
Blog entry by BritBoxmaker posted 06-01-2010 08:43 PM 3280 reads 2 times favorited 15 comments Add to Favorites Watch
« Part 2: Puzzling Part 3 of Snakes Pattern in Solid Wood series Part 4: The Union of the Snake »
Right I’ve re-arranged the dark and light maple to different areas of the board, matched grain patterns as much as I can and am now preparing for the glue up.
This above pic shows how I am planning to tackle partial glue-up if the glue setting time starts to become an issue.
The eight softwood sticks allow for straight rectangular clamping at glue-up.
This shows, at the top, the pattern ready for moving to the glue-up frame, bottom. The seperate right hand section of the pattern is the minimum I will glue-up and clamp using the above technique. If glue setting time is not an issue I’ll glue an extra two diagonal rows at the same time. If it is an issue I’ll just clamp this.
The frame is oiled to avoid glue sticking to it as are the sticks. Now I realise that oil contaminating the glue-line could cause problems. I am waiting till the oil on these sticks has thoroughly dried. In addition as a last minute fix I can always use waxed paper if I believe this is an issue.
So I’m gluing-up in sections of as much at a time as possible. This may cause issues but I’ve learned in life to experiment.
15 comments so far
View Jack Barnhill's profile
Jack Barnhill
366 posts in 3333 days
#1 posted 06-01-2010 09:03 PM
It’s always fun to see your posts. The different things that you attempt, and successfully complete, keep your posts exciting.
What king of oil are you using on the sticks? Have you ever tried using wax to keep the glue from sticking without seeping into a glue line?
-- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3003 days
#2 posted 06-01-2010 09:08 PM
Thanks, Jack. Its called Ecowoodoil (made by an Australian Company), I think its tung based, you can google it for more info. Its not the one I intend to use to finish the board. Hmm perhaps I should have used that. Oh well we live and learn.
No I’ve never tried wax, is that good then?
View Cozmo35's profile
Cozmo35
2200 posts in 3003 days
#3 posted 06-01-2010 09:25 PM
Martyn, your blogs are like a televesion series. I wait patiently for the next episode. It is entertaining as well as very educational!
-- If you don't work, you don't eat!.....Garland, TX
BritBoxmaker
#4 posted 06-01-2010 09:37 PM
Autumn, thank you and thanks for the background on the wax paper.
I’d hold off on the build until we see if the glue-up plan works.
Wonder Woman, thats it . If I’m Three Speed, you’re gonna be Wonder Woman, LOL
View degoose's profile
degoose
7228 posts in 3322 days
#5 posted 06-01-2010 10:06 PM
Martyn I now have a few days with only several projects on the go… in between I figure I may have some time to see how I go with my idea for this… the problem will be contasting timbers.. maybe purple heart and silver ash will give me a good result…
Yours if truly racing along…
BritBoxmaker
#6 posted 06-01-2010 10:13 PM
Sounds like a good wood combo, Larry. I’m very interested to see how your version of the snakes goes.
I think sycamore would have given me a better contrast with the walnut. Next time…
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3082 days
#7 posted 06-01-2010 10:29 PM
another great toturial you have made Martyn
it´s a amazing pattern you have created
this is a fantastic site with great bloggers like you Martyn
thanks a lot for taking your time to do them
I look forward to see the next installment
take care Martyn
Dennis
Jack Barnhill
#8 posted 06-01-2010 10:30 PM
I have used wax on cauls and battens to keep the glue from sticking and it works very well. Because it’s not a liquid like oil, it does not run, drip or seep into areas where you do not want it. Don’t use a wax that has silicon in it. A good, basic Carnuba wax works great.
BritBoxmaker
#9 posted 06-01-2010 10:33 PM
Thanks for that, Jack. Looks like a new set of sticks, waxed this time, are called for.
117063 posts in 3544 days
#10 posted 06-01-2010 10:36 PM
Well done Martyn your always so innovative in all your blogs.
View Mary Anne's profile
Mary Anne
1058 posts in 3176 days
#11 posted 06-02-2010 12:14 AM
I can hardly wait for the next exciting episode.
I tried waxed paper on my first glue job, but got it stuck in the glue joints while I was panicking over getting everything else right. I’ve had much better success with clear packing tape on my cauls.
View poroskywood's profile
poroskywood
618 posts in 3331 days
#12 posted 06-02-2010 03:10 AM
Right on.
-- There's many a slip betwixt a cup and a lip.--Scott
View sras's profile
sras
4790 posts in 3096 days
#13 posted 06-02-2010 04:11 AM
This is a cool story! Instead of wax paper, I make regular use of stretch wrap. It is thinner, wrinkles are not as much of an issue and glue does not stick at all. Oh yeah, and it stretches!
Looking forward to your next post…
BritBoxmaker
#14 posted 06-02-2010 09:08 PM
Go ahead, WW.
View stefang's profile
stefang
15881 posts in 3301 days
#15 posted 06-03-2010 08:03 PM
Waxed paper, another thing not available her. Another thing that works well is to wrap your cauls in clear wrapping tape. I do like the stretch wrap idea though. Your project is humming nicely along Martyn. I’m late in seeing this due to computer problems so I’m off to the next chapter! Enjoying the blog.
