Drum Sander #7: Stuck on Yew
Blog entry by BritBoxmaker posted 05-20-2010 06:14 PM 4756 reads 8 times favorited 24 comments Add to Favorites Watch
« Part 6: I hear the sound of distant drums Part 7 of Drum Sander series Part 8: One Year On »
I bet you’re all thinking “That darned fool has forgot to cut the little circular dents in the guide rails for when the drum is close to the table”, aren’t you?
Well I haven’t, so there. Here’s how I do it. Now the drum is a nice cylinder I attach two 1” strips of 60 grit to the ends using double sided tape.
Then I wind the table up, slowly, to cut them, so
The 60 grit and tape is then removed. I then applied the adhesive backed velcro ( 4” wide strip), in an anticlockwise spiral to the drum and fixed 150 grit velcro backed abrasive roll to the velcro. Just to be perverse and bridge the small dips at the edges of the adhesive backed velcro I wound the abrasive on in an opposite, clockwise, spiral. Bound the ends on with duct tape.
Fixed the hood and started to play. I tried a tricky piece of Yew. This is the best my planer (jointer) could do with it. Torn grain as you can see
After six or seven 5 thou passes with the sander, 150 grit, 950 rpm this was the result
No torn grain at all.
WOW, you were right, Autumn, I love my sander. I’ve been putting lots of things through it.
Including the Vortex4 pattern I blogged that I couldn’t get the Ebony dust out of the Pau Amarello on. Now its perfect
Steve’s (spalm) idea about putting a lip on the back of the ‘truing’ sled worked perfectly for sanding some small box sides (also Yew), thanks Steve.
What a brilliant tool. I don’t know how I worked without it.
There are some minor things left to do, like a paint job but I think thats about it for this blog. Hope you’ve enjoyed it, I have. Now I’m off to flatten every piece of wood in the shop, bye.
24 comments so far
View SPalm's profile
SPalm
5315 posts in 3783 days
#1 posted 05-20-2010 07:08 PM
Yew did it! Cool.
That sled can also be used for flattening warped boards by using shims under the work piece to keep it from rocking until the top is flat, and then removing the shims and flipping the board over. A lot of people use this technique for planers, but it works well for the sander too. I use this technique for cutting boards that always seem to glue up with some twist in them.
But now that you built it, you can modify it by adding a V-Drum type access on the top. Then it will become an abrasive jointer too. (And you thought you were done.)
Steve
-- -- I'm no rocket surgeon
View Mary Anne's profile
Mary Anne
1058 posts in 3110 days
#2 posted 05-20-2010 07:19 PM
Fantastic! What a grand accomplishment!
What fun to have that feeling of wondering how you ever did without it. Those tools are the best!
And better yet, that you built it and it actually works. :)
View Dennisgrosen's profile
Dennisgrosen
10877 posts in 3017 days
#3 posted 05-20-2010 08:08 PM
congrat´s with your new tool
hope it will serve you well
for many years to come
Dennis
View NewPickeringWdWrkr's profile
NewPickeringWdWrkr
338 posts in 2915 days
#4 posted 05-20-2010 08:22 PM
Solid effort! How did you find the resistance of pushing something through manually?
-- Mike - Antero's Urban Wood Designs http://anterosurbanwooddesigns.com
View spaids's profile
spaids
699 posts in 3595 days
#5 posted 05-20-2010 08:43 PM
This thing is all WIN! Great job. I was looking at specs for commercial drum sanders and saw that the two I looked at (jet, grizzly) both have their drum speeds pretty quick. Have you tried the 2000 rpm speed? You might like it.
-- Wipe the blood stains from your blade before coming in.--
View Cozmo35's profile
Cozmo35
2200 posts in 2937 days
#6 posted 05-20-2010 09:00 PM
TA-DAaaaa…... That’s how ya do it! Great Job Martyn!!! If you don’t have room in your shop I’ll send you my address! LOL!
-- If you don't work, you don't eat!.....Garland, TX
View HighRockWoodworking's profile
HighRockWoodworking
182 posts in 2881 days
#7 posted 05-20-2010 09:13 PM
Great job! The sander looks great and you get the satisfaction of building it yourself! Hope you really enjoy it!
-- Chris Adkins, http://highrockwoodworking.com/
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 2938 days
#8 posted 05-20-2010 10:07 PM
Mike, resistance is futile. No seriously no problem even with the oiled MDF table. Its good to have the tactile feedback. Table seems to be holding up quite well.
spaids, not yet it looks fierce though. Should be good.
Sorry Coz its mine, all mine.
Thank you all for your positive comments
View littlecope's profile
littlecope
3071 posts in 3403 days
#9 posted 05-20-2010 11:04 PM
May your sanding go ever smoothly, my Friend!!
Great Build!!!
View tyskkvinna's profile
tyskkvinna
1310 posts in 2887 days
#10 posted 05-20-2010 11:42 PM
Looks great! And super useful – and not too difficult.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Dan'um Style's profile
Dan'um Style
14171 posts in 3884 days
#11 posted 05-21-2010 12:00 AM
looks great and it is fun you got it working so well
13594 posts in 3242 days
#12 posted 05-21-2010 02:58 AM
great job there , martyn .
and in record time too .
proud for you !
now you can suffer even less for your arts sake ,
way to go ,bro !
View blackcherry's profile
blackcherry
3337 posts in 3724 days
#13 posted 05-21-2010 03:15 AM
Great work and accomplishment now it’s play time!
View jm82435's profile
jm82435
1285 posts in 3643 days
#14 posted 05-21-2010 03:35 AM
I think once you have one you would never be without one again. The results speak for themselves – great job.
-- A thing of beauty is a joy forever...
BritBoxmaker
#15 posted 05-21-2010 07:09 PM
2000rpm, fast, fierce but FUN!
You can feed twice as fast. You get a more uniform finish. You also get loads of dust (I’ll have to uprate my dust extraction) and accelerated wear of the abrasive.
450rpm
You could grow old waiting for the piece to be sanded.
950 rpm
Good compromise. Speed vs. dust. Minimal abrasive wear.
Still good having the choice though.
Materials cost £74.43 (I’ll leave you to work it out in your local currency) but weigh this against the general cost of a small commercial machine of around £550, locally.
Martyn
showing 1 through 15 of 24 comments
