A personal challenge - The make #2: Day 2
Blog entry by BritBoxmaker posted 05-06-2010 07:11 PM 2138 reads 1 time favorited 10 comments Add to Favorites Watch
« Part 1: A personal challenge - The make #1 Part 2 of A personal challenge - The make series Part 3: Day 3 »
Hello again. Day two of the challenge. I decided to measure up everything and arrange it before me to see what materials I have to make this box.
It didn’t take long to decide on a four sided box. I will make it vertically grained as this is where I have most length in the flitches and I’ll loose at least 2mm height when I seperate the box halves, top from bottom . Another piece will be the bottom of the box and the last will be the lipping for the inside, this will locate the top.
The next thing to catch my eye was the (relatively) enormous piece of Sycamore. If I cut this into six 3mm square lengths I could use these for corner pieces for the sides (butt jointed) and a border for the top (mitred).
Brilliant. But, as you can see, like most best laid plans this one went slightly awry. When cutting the Sycamore (same ZC clearance jig as yesterday) one of the pieces was caught by the saw blade and flung off who knows where. Unless I find it I only have five 3×3x70mm pieces and may have to join the top borders. A minor inconvenience. I’ll already have to join two of the sides corners.
The rest of the pieces are planned to make up a chevron pattern for the top, so.
Once they’re sized to 8mm deep there should be enough material there for this.
Martyn (in Lilliput) signing out
Addendum
I found it. Looks like the saw chewed it a bit before it spat it out. Don’t know if I can rescue any of it.
Yes! 34mm.
10 comments so far
View David "Lucky Dawg" Brown's profile
440 posts in 2992 days
#1 posted 05-06-2010 07:45 PM
Awesome!
I can see it already!!
-- dumpster diver delux
View Cozmo35's profile
Cozmo35
2200 posts in 3035 days
#2 posted 05-06-2010 07:58 PM
Martyn, It is like watching a good movie unfold! I can hardly wait for the next episode! I hope you find the flying wood….
-- If you don't work, you don't eat!.....Garland, TX
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3036 days
#3 posted 05-06-2010 08:01 PM
So do I Cozmo. Things could get a bit tight otherwise.
As for the movie I think the box (office) will not be that large.
Martyn
#4 posted 05-06-2010 08:04 PM
hahahaaha!
View littlecope's profile
littlecope
3071 posts in 3502 days
#5 posted 05-06-2010 09:35 PM
Great Blog, Martyn… You’re inspiring me to “think small” again, and revisit the scraps… Thanks for that!!
Be Extra-Careful with those little pieces!!
View stefang's profile
stefang
15881 posts in 3334 days
#6 posted 05-06-2010 10:44 PM
So THAT’s how woodworking is done! I’ve always wondered and now I know. This is getting exciting and I’m beginning to sense a successful conclusion (providing you still have all your digits at the completion of the project) Martyn).
View tyskkvinna's profile
tyskkvinna
1310 posts in 2985 days
#7 posted 05-06-2010 10:46 PM
Awesome! :) It’s starting to look real.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View OutPutter's profile
OutPutter
1199 posts in 3990 days
#8 posted 05-07-2010 04:51 AM
I thought this was going to be an inches project. No wonder you don’t have any materials. With all those metrics flying around you’re bound to get lost and confused. No doubt the sycamore was in metric and the saw was in inches. Anyway, I’ve heard you do a pretty good box so I’ll prolly keep following this. Just to see you know, if you can really make a box without a single inch.
-- Jim
View lumberdustjohn's profile
lumberdustjohn
1263 posts in 3166 days
#9 posted 05-07-2010 01:02 PM
Somewhere I have read this.
It must pertain to this project.
Size doesn’t matter?
-- Safety first because someone needs you.
View Houtje's profile
Houtje
311 posts in 2971 days
#10 posted 05-08-2010 05:44 AM
Martyn it’s great what you are showing use!!!
Can’t wait to see the next episode.
Thanks for sharing
