Restoration #1: Microscope box for Museum
Blog entry by BritBoxmaker posted 1156 days ago 885 reads 0 times favorited 9 comments Add to Favorites Watch
no previous part Part 1 of Restoration series no next part
The local museum I volunteer at has just acquired a microscope, late 19th or early 20th century. Unfortunately the box for it is in a bad state of repair
Hence the elastic bands holding it together and the damaged veneer on the top. Well the curator has asked me to repair the joints, clean it up but don’t repair the top. This is because the authenticity of the object would be lost. Heres the inside
Plenty of cleaning and a little repair to do here. I’ll probably be taking it apart, in order to clean the glue off the joints, before I clean it and glue it back together. I’ve ordered up some animal glue, for authenticity, so the fun should start soon. Keep watching.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
9 comments so far
View Cozmo35's profile
Cozmo35
2141 posts in 1232 days
#1 posted 1156 days ago
Looking forward to seeing the final product. I am sure you’ll do a great job!
-- If you don't work, you don't eat!.....Garland, TX
View NewPickeringWdWrkr's profile
NewPickeringWdWrkr
338 posts in 1210 days
#2 posted 1156 days ago
Cool project. Looks like fun. I look forward to hearing about your experiences.
-- Mike - Antero's Urban Wood Designs http://anterosurbanwooddesigns.com
View rons's profile
rons
72 posts in 1548 days
#3 posted 1156 days ago
Hey Martyn I,m sure you’ll do a great job. keep us posted…Thanks Ron
-- Ron, Michigan
89038 posts in 1774 days
#4 posted 1156 days ago
Looks like you’ve got a job ahead of you.
View David Craig's profile
David Craig
2128 posts in 1305 days
#5 posted 1155 days ago
Is this your first restoration for the museum? I know you volunteer there, but was curious if this request was outside the norm or not. Quite a honor to be trusted with such a delicate task.
David
View BritBoxmaker's profile
BritBoxmaker
4054 posts in 1233 days
#6 posted 1155 days ago
David – Yes its my first for the museum but I’ve done some before. Jenny, the curator is familiar with my work from other things I’ve made for them. I’ve also done some cleaning work on objects at the museum.
Autumn – The grain for the veneer on the top is opposing the wood underneath, which appears to be solid but I’ll find out if I need to take it apart. I would like to replace the veneer but the brief is to keep the box as original as possible. The box has slipfeatered mitre joints. The right lower side is totally loose and the slipfeathers are broken / missing. Its going to be fun replacing them. The internal work is mostly simple butt joints. Not the best of construction but once its back in one piece it’ll see a lot less wear in the museum than in its previous life.
Incidently I’m not doing the microscope cleanup but I hope to get at least one pic with it in situ once I’ve done my bit.
Martyn
View lumberdustjohn's profile
lumberdustjohn
1167 posts in 1363 days
#7 posted 1155 days ago
Good luck,
Post the pictures together when completed ( before and after.)
Thanks for posting
-- Safety first because someone needs you.
BritBoxmaker
#8 posted 1154 days ago
Autumn – running the grain of substrate and veneer does allow for movement but you can open yourself up to cupping due to grain shrinkage if you dont get it right. I know I’ve suffered with this (or at least my work has) once or twice.
Regards
Martyn
BritBoxmaker
#9 posted 1154 days ago
Yup thats the one. lol
Martyn
