Jigs etc. #1: Mitre Jigs
Blog entry by BritBoxmaker posted 04-10-2010 07:06 PM 5973 reads 12 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Jigs etc. series Part 2: The old 60° »
Here are the mitre jigs (sleds) that I use for my box sides. The first is a typical 45 degree job with a square blade guard, there is a stop block underneath (not shown).
There are two additional features however. The first are the two clear perspex stops, for repeatability of cut length, nothing unusual there.
The second is something I’ve started to use to prevent tear out of the end grain on the mitred end. These are adjustable sacrificial jaws attached to the outsides ouf the mitre arms. These are Iroko but any scrap timber, or MDF, will do.
I find that however well adjusted the blade is, for squareness, over a period of time the tips of the mitre arms (where the blade passes through) will wear and the gap become wider. This leads to tear-out of the end grain on the inside of the mitre on the box side being cut. Even with an 80 tooth blade. At the beginning of doing a batch of sides I bring both jaws into the centre of the saw cut region (loosen cross-head screws, move jaws in, tighten cross-heads). Having squared up the blade beforehand I do a pass with no timber on the jig to open up the jaws again. Each time this is done the jaws are good for cutting about a dozen boxes worth of sides, with no tearout.
The second jig is the 60/30 degree one I used for the Vanishing Point box. It has a stop block underneath (not shown).
As its a fresh jig there are no sacrificial jaws fitted yet. However I’ve used the rear section for a dust extraction port this time.
I’ve also used the fact that there is active dust extraction (and therefore partial vacuum) to provide a degree of holding for the box side being cut.
The three holes (3mm diametre) are bored through the whole depth of the mitre arm and allow the ‘borrowing’ of some of the vacuum of the dust extractor to hold the piece being cut onto the mitre arm.
My next project is to adapt the first jig for dust extraction/vacuum holding. After that possibly an adjustable angle jig.
7 comments so far
13608 posts in 3368 days
#1 posted 04-10-2010 07:14 PM
looks pretty atomic !
great jigs ,
and the under stop idea is great ,
for those absentminded cuts .
thanks for sharing !
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3063 days
#2 posted 04-10-2010 07:20 PM
Well spotted David!
View Ger21's profile
Ger21
1074 posts in 3158 days
#3 posted 04-10-2010 08:02 PM
The sacrificial faces are an outstanding idea. Some day, when I make a sled, I’ll be sure to incorporate them. If I remember. :-)
Well Done.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View SPalm's profile
SPalm
5320 posts in 3909 days
#4 posted 04-10-2010 08:41 PM
Sweet. I also have a 45 miter sled and find it very useful. I like the replaceable faces and under sled stop block too. Good thinking.
I never thought to apply it to a 60/30 sled. Again, you are a clever guy. Any hints on how to get it set to 30/60? I guess if you have one set, the other follows, but how to get the first set? Trial and error certainly works.
Steve
-- -- I'm no rocket surgeon
BritBoxmaker
#5 posted 04-10-2010 09:48 PM
Steve. Assuming you already have a base attached to its runners first make sure the blade is set parallel to your mitre guage runners (slots). Cut a full slot into the base using the saw’s blade. I set the 60 degree side up first. Having already cut the end of the mitre arm to 60 degrees using my saw’s mitre guage i put a strip of double sided tape along it’s bottom face. With the sled pushed fully forward set the tip of the 60 degree side to the position where the blade is at max. height. Using a protractor or a similarly cut sheet of scrap set the mitre arm at 120 degrees to the blade. Stick the arm down. Drill and screw the arm to the sled from the underside. Cut the 30 degree arm to 30 degrees at its end and tape up the underside. Using your best wooodworkers square to set it 90 degrees from the 60 degree side. Stick down and screw home as before.
Martyn
View bigike's profile
bigike
4052 posts in 3316 days
#6 posted 04-11-2010 12:30 AM
great ideas, i like the one with the dust extaction.
View Cozmo35's profile
Cozmo35
2200 posts in 3063 days
#7 posted 04-12-2010 02:11 PM
It looks like you put a lot of thought into the design of these jigs! I am sure it will carry through to your boxes.
-- If you don't work, you don't eat!.....Garland, TX
