Bandsaw boxes #2: Tiger Tiger
Blog entry by BritBoxmaker posted 04-07-2010 03:47 PM 5082 reads 3 times favorited 11 comments Add to Favorites Watch
« Part 1: The Eyes Have It Part 2 of Bandsaw boxes series no next part
Outside my comfort zone again. This is my second experiment with the bandsaw and patterns.
Materials are Yew and Ebony. The patterns are about 50×120mm and 7mm thick.
They’re more like Tiger and Anti-Tiger as one is obviously the negative of the other.
Can’t make my mind up whether to make two individual boxes or slap them together lengthways to make one long pattern for something like a pencil box.
Front side
Back side
Side by side
Or I could slice them through the thickness and make two pencil boxes. Decisions, decisions.
Well I couldn’t resist it. I split the patterns. A bit like cloning
So two pencil boxes with sliding lids here we come.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
11 comments so far
View jm82435's profile
jm82435
1285 posts in 3618 days
#1 posted 04-07-2010 06:10 PM
or bookmatch them for the fiddleback look…
-- A thing of beauty is a joy forever...
View skeeter's profile
skeeter
233 posts in 3217 days
#2 posted 04-07-2010 07:18 PM
I like the last one best. Man that is sweet
-- My philosophy: Somewhere between Norm and Roy
View Cozmo35's profile
Cozmo35
2200 posts in 2912 days
#3 posted 04-07-2010 08:57 PM
WOW!
-- If you don't work, you don't eat!.....Garland, TX
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3162 days
#4 posted 04-07-2010 11:11 PM
Cool looking pieces
Thanks
-- http://shepherdtoolandsupply.com/
View David Craig's profile
David Craig
2137 posts in 2985 days
#5 posted 04-08-2010 12:28 PM
William Blake would be proud…
David
View Triumph1's profile
Triumph1
885 posts in 2955 days
#6 posted 04-08-2010 01:39 PM
I love experiments:-) Did you find that the bandsaw left a nice enough surface that no gaps were seen when you glued the pieces back together? I know stacking the pieces while cutting makes an almost identical saw cut in both pieces just wasn’t sure if it turns out to be a “perfect” joint.
That is a very cool idea though and I would say the results of the experiment were extremely positive!
So is it four pencil boxes all together or are you gluing the split pieces to make just two lids? Can’t wait to see the results.
-- Jeff , Wisconsin Please...can I stay in the basement a little longer, please!
View BritBoxmaker's profile
BritBoxmaker
4610 posts in 2912 days
#7 posted 04-08-2010 02:22 PM
Jeff
The edge finish is ragged but both halves usually lock within about 1/2mm of the original location. Most times you loose the odd millimetre at the edges of the pattern due to staggered location.
Its going to be two pencil boxes and I may have to make a totally new piece for the join in the predominantly yew version, the Ebony joins almost seamlessly.
So off for some fun with s dovetail router bit!
Martyn
BritBoxmaker
#8 posted 04-08-2010 04:28 PM
Incidentally Jeff for the real knowledge on this method read Patron’s blogs. There’s some really good stuff in there.
Martyn
View mtkate's profile
mtkate
2049 posts in 3201 days
#9 posted 04-09-2010 06:22 PM
Wow – amazing
View kevinw's profile
kevinw
190 posts in 3615 days
#10 posted 08-21-2010 06:37 PM
Do you use a really thin blade or how do you get the pieces to fit together so well?
-- Kevin, Blue Springs, MO
BritBoxmaker
#11 posted 08-21-2010 06:59 PM
Kevin. The technique involves double sided taping two sheets of dissimilar wood together and sawing them on a bandsaw with a standard 1/4” blade. This will leave the sides of any pattern slightly stepped by the blade cut which will lock if you slide the pieces slightly. Both types of wood were cut at the same time in exactly the same way. So you can mix and match the two precisely.
