This is an earlier project of mine that also neatly shows one of the simpler box making techniques I use, that of the mitred box with drop-on lid. First we see the basic components:
On the left are the four sides, each with a 3mm slot routed in near the bottom to hold the base. The base is bottom right and is two layers of 1.5mm birch aeroply. The top is the last piece, top right. This particular one is a three layer sandwich; 3mm design, 3mm ply and 3mm maple (this bottom 3mm will locate the lid on the box.
First you mitre the corners of the box sides. Sand the insides of the box and apply sanding sealer to all but the top 6mm of each side. Lay them out, in order, above a 50mm strip of masking tape (sticky side up), below which is a straight edge to line the bottom edges up on. Lay them onto the tape.
Place the top and bottom (this one in the slot) on one side and wrap the sides around them. Check for size/ gaps and adjust top or sides accordingly.
Apply PVA glue to the mitred edges and the top 6mm only of the sides. Close the box up again using the tab left over (to the right, Step 3) to hold the box closed. I used to just use this to hold the box whilst the glue dried but found that the last joint was never as tight as the other three. So I put together a windlass clamp.
This is four identical pieces of softwood with a right angled notch in one end and a hole for some string to hold them together with. Oh and a pencil or stick to tighten it up with. So
Tightening the pencil provides even inward pressure on each corner of the box whilst the glue dries. When its has remove it and all the tape and sand the top down flat (theres always a slivver of something out of line).
Next we need to cut the top off.
This is done on a router table with a 3mm slot cutter bit. Cutting through the last 1/2mm with an xacto knife until you have a seperate top and box.
Sand the top of the box and all outside faces to finished.
Apply sanding sealer and polish.
The wax polish I’ve been using for many years now is by Organoil, an Australian company. Beautiful finish and nice spicy citrus smell (my customers enjoy smelling the boxes as welll!). Next line the bottom. I use a foam called Funky Foam. Comes in various colours and easy to cut with a knife.
So here we have it the completed Black and White dots box.
The overall box dimensions are 96×96 x 50mm. The materials are Purpleheart, Ebony and Maple. No dividers in a box this size as there doesn’t seem much point. Oh and no slipfeaters in the corners. If it can’t stand my 76Kg (160lbs odd) of weight standing on it, and this did, only then does it need them.
Simples!
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
23 comments so far
JamesVavra
home | projects | blog
255 posts in 1487 days
#1 posted 1148 days ago
Great tutorial.
James
Derek Lyons
584 posts in 1739 days
#2 posted 1148 days ago
Nice tutorial – thanks!
-- Derek, Bremerton WA --
Dennisgrosen
10854 posts in 1286 days
#3 posted 1148 days ago
great tutorial
that´s is something
everyone can understand
Dennis
Cozmo35
2138 posts in 1207 days
#4 posted 1148 days ago
VERY WELL explained! Thank you!!
-- If you don't work, you don't eat!.....Garland, TX
DaddyZ
2008 posts in 1211 days
#5 posted 1148 days ago
Cool show – how to !!!
BritBoxmaker
4011 posts in 1207 days
#6 posted 1148 days ago
Thanks guys.
Martyn
Fireguy
132 posts in 1406 days
#7 posted 1148 days ago
nice clamp, I have not seen that one before.
-- Alex
BritBoxmaker
#8 posted 1148 days ago
Cheap too Alex, pennies if that!
12067 posts in 1512 days
#9 posted 1148 days ago
well done martyn ,
free pass to the next
geometry expo for you !
nice design and execution .
so if you stand on a finished box ,
and i breaks ,
you have to make another one ,
to put splines in (LOL) ?
rons
72 posts in 1522 days
#10 posted 1148 days ago
Hi Martyn Ive been enjoying your tutorials alot… That clamp was a good idea. Can’t wait to see more from you. Your boxes are great. Thanks Ron
-- Ron, Michigan
jm82435
1217 posts in 1913 days
#11 posted 1148 days ago
Great tutorial, thanks. I really like your work – your boxes are fantastic.
-- A thing of beauty is a joy forever...
BritBoxmaker
#12 posted 1147 days ago
Yep. If I stand on it and it fails I make another one. First however I look carefully over the old one to learn of any failures, in glue line etc. If there are none I put splines in the second one. I would spline a mitred box over 200mm anyway or one with very thin wallls.
I know all the technical stuff, about end grain to end grain being the weakest joint and along the grain being stronger. I use common PVA glue, nothing special. Apart from actually throwing the things, corner first, at a concrete floor I don’t get many failures. The concrete floor experiment was spectacular by the way but only two joints failed.
So what do you guys in the US do to these things, over and above standing on them, that makes splines a necessity?!!! lol
Martyn
BritBoxmaker
#13 posted 1147 days ago
I’m not prejudiced against the use of splines, by the way. They are a technically elegant solution. I just prefer a plain corner.
Martyn
#14 posted 1147 days ago
i give a lifetime guaranty on my boxes ,
my life ,
your life ,
or
the life
of the box .
which ever comes first (LOL) !
BritBoxmaker
#15 posted 1147 days ago
lol
View all comments »
showing 1 through 15 of 23 comments
