"Why is This Car Parked in My Shop?" Turning My One Car Garage Into A Shop #2: Kreg Top Track Production Stop/Chop Saw Outfeed Table/Fence
Blog entry by Brad_Nailor posted 03-22-2010 04:12 AM 8050 reads 4 times favorited 8 comments Add to Favorites Watch
« Part 1: Moving the Hand Tools In...Installing A French Cleat System Part 2 of "Why is This Car Parked in My Shop?" Turning My One Car Garage Into A Shop series Part 3: New FWW laminated Plywood Work bench »
I recently got a great deal on a Kreg precision measuring kit at wood shop liquidation sale. I was considering buying the kit brand new for $140 bucks… I got this one for $25, but it was missing all the hardware. I sent an email to Kreg explaining my situation and asking if they could sell me the replacement parts and they promptly answered back saying they would send me out all the hardware I was missing for free! I can’t say enough great things about Kreg and their customer service. A week later I received a package containing all the hardware I was missing and one each of the left and right reading self adhesive tapes. I didn’t even ask him for those..you can buy them anywhere…but he included them anyways! Awesome!Thanks to the great customer service rep at Kreg!
So I decided I was going to build a simple out feed table out of 2×4’s screwed to the wall studs and 2×4 legs. I topped it with 3/4” shop birch and 1/8” hardboard. I used a light coating of contact adhesive so I can change out the hardboard if it gets all messed up. I kept the chopsaw on the cabinet I made for it, and once in the position I wanted it in I locked all the wheels and shimmed it so it is level. The out feed table legs nearest to the cabinet I turned so the long side is facing the cabinet. I drilled holes and installed 3/8” x 2 1/2” lag bolts and washers to lock the two together. I made the fence from 3/4” melamine for the face and 3/4” birch for the base, pocket screwed together. The fence is 2 1/4” high per the Kreg specs for the stops to work right. Here is the finished fence before I mounted the track to it..
It’s screwed to the table top with 1 1/2” pan head screws. The top track is attached to the fence with #8×5/8” pan head screws. It’s pretty easy to dial in the tape placement and the curser of the stop..in a couple minutes and a few test cuts I had it dialed in as accurate as my Biesmeyer!
I also threw together a dust hood for my chop saw. I made it out of scrap hard board, scrap MDF, and scrap 1/2” Baltic birch.
I used a table top dust collection fixture mounted under the box. I mounted it to the wall on a french cleat that way I can slide it to the left to do angle cuts. It works pretty good at sucking up most of the dust…..allot better than no hood. I also used some pool hose to direct the saws built in dust collection port down into the collector.
My little shop is starting to come together! I will probably put up a piece of solid wood trim on the front of the out feed table. I have allot of storage behind the fence and I will be putting up more french cleat storage and maybe a cabinet as well. It’s a bit of a reach over the wide counter top but I am tall so It’s not too bad. Next on my list is a real bench to replace the door on two saw horses I have now! Also I want to make a nice drill press table with a movable fence.
8 comments so far
View Marc's profile
Marc
101 posts in 2918 days
#1 posted 03-22-2010 04:50 AM
Looks great! I like the sliding french cleat idea. When I was first looking at the pictures I thought the dust collection hood was going to get in the way during angle cuts. (Then I actually read your notes.) :-)
-- Marc, http://www.logicallymarc.com/
View woodnewbee's profile
woodnewbee
76 posts in 3016 days
#2 posted 03-22-2010 05:04 AM
Great detail on how you put it all together. I am getting my equip and building together so all the ideas i can get are appreciated. Will definately keep this one in mind.
View BradHess's profile
BradHess
63 posts in 2922 days
#3 posted 03-22-2010 05:09 AM
Love the setup and might have to do something similar. I second the Kreg support. I have one of their miter gauges that I dropped and broke the cursor. I emailed them and they immediately sent one out without charging me a dime.
View ND2ELK's profile
ND2ELK
13495 posts in 3683 days
#4 posted 03-22-2010 10:21 AM
Looks good. Great mind must think alike! I have the same brand saw and stop system. I did something similer to yours if you care to look in my projects. Thanks for posting.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View SPalm's profile
SPalm
5316 posts in 3791 days
#5 posted 03-22-2010 02:41 PM
Looks great! So nice and clean too. I always try to keep my stuff inside some sort of enclosure so that it is easier to keep clean. I was thinking some kind of box/cabinet/over-shelf storage thingy behind the fence would keep the fine dust easier to manage. Of course then you have to remember what is in there.
Steve
-- -- I'm no rocket surgeon
View GaryD's profile
GaryD
623 posts in 3279 days
#6 posted 03-22-2010 04:20 PM
Looks good to me, I too am making my one car garage into my shop. Space is definitly at a premium. But cant wait it will be bigger than anything I have ever had.
-- Gary, Little River,SC I've Learned that the Lord didn't do it all in one day and neither can I
View Cato's profile
Cato
701 posts in 3222 days
#7 posted 03-22-2010 10:37 PM
Brad- Nice job on the miter saw station. I need to do something similar for support and dust collection for mine. Stop system would be nice to have for repeatable length cuts.
View bigike's profile
bigike
4053 posts in 3198 days
#8 posted 03-22-2010 10:58 PM
great set up
