Well I have been so focused on getting my new old Unisaw tweaked and settled in it’s new home I forgot that I need some essentials for it’s operation. I wanted to fire it up and try and cut some big slabs of birch butcher block to test its power, but I realized one thing…they are big pieces and I don’t have an out feed table! So, basically I cant cut anything bigger than 10 inches…and what fun is that? So I was browsing through the projects and came upon this project by Jayman7. He did his interpretation of an out feed table by Marc “The Wood Whisperer” Spagnuolo, who got his inspiration for his table from Norm . I liked the design allot, it was simple..all plywood and looked pretty sturdy. So…I went to Marc’s website and proceeded to watch his video of the construction of his out feed table. I also read all the comments everyone left and their was some really excellent suggestions and observations. So, I sat down and put together my version of everyone else’s version of this table! I kept the basic design and just modified the dimensions to fit what I needed for my saw. Click on the link below the image to see it full size.
FULL SIZE OF ABOVE IMAGE
I added threaded post Woodcraft double locking casters, and I also covered the entire top with a piece of 1/4” (actually all HD had was 3/16”) hardboard. I wanted to be able to roll it out and flip it long ways if I’m ripping whole sheets, and be able to support the width of a sheet for long cross cuts. I also extended the sub top and hardboard out 2” to form a lip that can extend over the back rail for my fence. This way I can but the table right against the end of the cast iron…no gaps. Jayman gave me the idea of using the hardboard and someone that commented on Marc’s project suggested a unified top due to the ends of the plywood swelling and expanding above the plywood top and causing a catch hazard….so I am going to cut the hardboard oversize and glue it downs sparingly so I can get it off if I want to change it out in the future, and then I will just cut it flush with my router and a flush trim bit. Here is a another shot of the SketchUp model. This is the exploded view scene…
I did the post mount casters so I can use a threaded insert or capture nut and jam nut to do a fine hight adjust, so I can get the table dialed in to the perfect hight. I also added a little more support under the top to prevent sagging and beef it up, because you know it’s going to be more than just an outfeed table!
In Jaymans thread, somebody asked him to do a SU model of the table for everyone to use. I volunteered to do it, and I am a man of my word..so here it is! Click on the link below and download your own copy of my version of this out feed table. There are 11 different view tabs including complete dimensions and I even did 3D cutting diagrams! Anyone with a basic SU knowledge could easily modify the pieces to fit there unique application. Or, print out all the tabs and build one just like mine! Download the SU model here
So after I got this done it was off to Home Depot to buy some plywood. I noticed their birch ply is American made, with no scary Chinese chemicals or dead rats in it. I have tried it out on a couple shop cabinets and it seems to be OK..and at $39.00 a sheet you cant go wrong for shop fixtures. So three sheets of that and one sheet of 3/16” hard board..$139.00. Not too bad..and I will have some usable scraps. Fire up the table saw!
16 comments so far
WayneC
home | projects | blog
9596 posts in 2267 days
#1 posted 1271 days ago
Nice drawings. I need something similar.
Brad_Nailor
2450 posts in 2127 days
#2 posted 1271 days ago
Thanks Wayne. Feel free to download the SU drawing and build one of your own. They offer a SketchUp viewer if you just want to print out and view SU files without modification..it’s on their download site.
WayneC
#3 posted 1271 days ago
Will do. Thanks.
Richard Williams
160 posts in 1962 days
#4 posted 1271 days ago
“Never put a Wishbone where your Backbone ought to be.” You have proven that to all of us. Nice engineered design. I’m proud of you my friend. Everyone on this web site community is much more of a carpenter than I am. I am always amazed at what all of you can do with wood. All of you guys and gals are terrific in my book. Keep making wood chips. Happy Thanksgiving to all as a belated message.
-- Rich, Nevada,
CanadianWoodChuck
360 posts in 2084 days
#5 posted 1271 days ago
Dave: Thanks for your SU rendition that should work out great for you. You will likely need cut outs for your mitre gauge, alignment might be a small issue because of the castors. Just a thought! Nice SU drawing, Where did you find the plywood material? I haven’t seen that one.
Bruce
27262 posts in 1992 days
#6 posted 1271 days ago
David, this will be a nice addition to your shop. You have a good design to it and I like the extra support you have added. I have found that, despite best intentions, plywood tops tend to bow if not supported. In most situations this is not a problem but on an outfeed table it needs to stay flat in order to avoid catches. And thanks for sharing the SU drawings.
john
2238 posts in 2552 days
#7 posted 1270 days ago
You sure make that look easy !!
-- John in Belgrave (Website) http://www.extremebirdhouse.com , http://www.facebook.com/group.php?gid=112698715866
Jimi_C
506 posts in 1405 days
#8 posted 1270 days ago
Very nice. I was helping a friend pickup some furniture from a store for his new business, and noticed the store next door had a 2x/plywood display table with a plastic laminate top sitting by their dumpster. I need to head back up there today to see if it’s still there, since it was perfect for an outfeed/assembly table. If it’s not, I’ll be looking to build a table of this style.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
Brad_Nailor
#9 posted 1270 days ago
Thanks for the comments guys!
Bruce Ya, I have considered the miter slot issue, and I might plow a few groves in the top..but I don’t really use the miter gage on my table saw much, and with a 50” fence I don’t see even making a crosscut sled, so I’ll cross that bridge when I come to it! The Maple plywood texture was from a 3D render materials website..I have a pretty extensive library of components, textures and backdrops. Can you elaborate on what problems you think i might have with alignment from the casters? I put them in for mobility and picked the threaded post style to be able to adjust them up and down..
CanadianWoodChuck
#10 posted 1270 days ago
Dave (brad) I just thiught if you put the miter slots in you would have to get it lined up exactly each time so the tracks would line up. I like the castors they are an excellent idea. Sorry for the confusion.
Dave R thanks once again for the SU help, that works really well.
bigike
4023 posts in 1458 days
#11 posted 1270 days ago
this is a sweet table to put projects together and leave them to dry after glueup nice simple sturdy job.
jwicks
54 posts in 1778 days
#12 posted 1269 days ago
Looks good! I built a version of this table earlier this year.
It’s a must for cutting large sheet goods on the table saw and has been a great place to assemble projects. I like the idea of adding a replaceable hardboard top. I did that for the shop cabinets I just built and wish I had for the assembly table. Recently I’ve been thinking about adding a laminate top.
I’ve also avoided adding miter slots to it but I think I will add them soon as I am sick of pushing the table out of the way when I make wide crosscuts.
-- Jon
OhVlyArtisan
605 posts in 1290 days
#13 posted 1269 days ago
Yup I need a new outfeed table as well
-- "All you need in this life is ignorance and confidence, and then Success is sure." Mark Twain
Brad_Nailor
#14 posted 1269 days ago
Thanks Jon…That design is pretty tried and true and the more I look the more variations I see of it. It’s going together really nicely, and I cant wait to put it in place behind my saw!
Beginningwoodworker
13225 posts in 1843 days
#15 posted 882 days ago
Those are some nice drawings.
-- CJIII Future cabinetmaker
View all comments »
