Tool box #5: Back panel
Blog entry by Boatman53 posted 64 days ago 918 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 4: Dovetailing the box Part 5 of Tool box series Part 6: Some tools for the box »
Got some more work done on the tool box earlier this week. I made and fitted the back panel. All stock is half an inch thick and the first step was to cut he pieces just a bit long, then cut a groove on one edge to hold the panel.
Them drill out the waste for the mortise.
Most of it chiseled out, the width is only a bit over 1/8”.
I needed to dig out a little chisel to pare down the sides, all of my other chisels were just too thick.
Then the tenons were cut and fitted.
All the pieces fitted and layed out.
All the joints are glued and clamped. I do not keep my shop heat on at night so I have this setup to keep the projects moving.
The panel all glued and sanded.
And fitted to the back of the box. A slight ledge/rebate was routed on the sides to register the panel and give a really clean joint.
That it for now. I’m still rearranging the tool layout looking for the best option.
Jim
-- Jim, Long Island, NY Ancorayachtservice.com home of the chain leg vise
10 comments so far
View Mauricio's profile
Mauricio
5102 posts in 1317 days
#1 posted 64 days ago
Looking good Jim. I like your glue set up.
Do you have different DT layouts on each corner?
View doordude's profile
doordude
862 posts in 1148 days
#2 posted 64 days ago
looks like a great looking box
View Brit's profile
Brit
4183 posts in 1008 days
#3 posted 64 days ago
Lovely work Jim and thanks for documenting your progress with all the photos. It won’t be long now.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
View stefang's profile
stefang
9436 posts in 1500 days
#4 posted 64 days ago
Nice work Jim. A very even reveal around the panel too.
-- Mike, American in Norway
View Boatman53's profile
Boatman53
411 posts in 362 days
#5 posted 64 days ago
Thanks my friends. Mauricio the dovetails are different top to bottom not side to side. Thanks Mike, when I fasten in the tool holders the panel will have a screw or two through it to lock it in the middle.
Jim
View terryR's profile
terryR
1105 posts in 474 days
#6 posted 64 days ago
Looking nice, Jim, can’t wait for the finish to let the wood shine!
Love your drying tent…hula-hoops cut in 1/2? :)
-- tr ...see one, do one, teach one...
View Napaman's profile
Napaman
5010 posts in 2243 days
#7 posted 64 days ago
looking really good!
we have that same exact heater (which does not get used in southern california much) and I know it can get hot…is it safe in the shop overnight? Sorry I get nervous about these things…
-- Matt--Proud LJ since 2007
Boatman53
#8 posted 64 days ago
As to my glue curing tent… The hoops are PEX water pipe I bought about 20’ for around 12$ if I remember right. That gave me a couple different size hoops.
The heater has a minimum clearance of more than a foot all around. I use the low 600 watt setting and it is plugged into a timer so it will shut itself off at my choosing. Which is nice if I’m not going to the shop the next day for some reason. I usually run it about 12 hours so in this case it went off about 1AM. I think they are the safest heaters around.
Jim
Napaman
#9 posted 63 days ago
ok…sounds safe! Like I said we dont use ours toooo much in CA…either way love the progress!
Boatman53
#10 posted 62 days ago
No problem napaman I appreciate the concern.
Jim
