Since no one could give me a reason not to use the different dovetail spacing I went ahead cut the two styles that I liked. End to end comparison.
The pin board is offered up to it’s mate to mark the tails. Since there are many to mark I took the time to clamp everything so it wouldn’t shift.
Next came the cutting out. Yes I use the band saw. When I made the samples I cut to the line and assembled them right from the saw, I did no paring. The teak isn’t quite as forgiving, so I left a little wood in the waste side of the line so I could hand fit everything.
First one is done.
Second one is done.
Third and forth are done, but I should have waited till tomorrow. It was getting late and I wanted to finish tonight. I pared just a bit too much and got some gaposis. Not bad where it is and easily fixed, but still wish I had taken my time.
Here is the box assembled.
Thanks for following along.
Jim
Next will be to make the back panel. I’m going to hold off gluing the box together till I make and fit all of the dividers and tool supports, some of which will be morticed into the side.
-- Jim, Long Island, NY Ancorayachtservice.com home of the chain leg vise
11 comments so far
bobasaurus
home | projects | blog
684 posts in 1349 days
#1 posted 72 days ago
Nice dovetails. I use the bandsaw when cutting out tails, too.
TopamaxSurvivor
13192 posts in 1841 days
#2 posted 72 days ago
Nice work. Dovetails are as much about aesthetics as structure in most cases, my opinion. If you like them, they are perfect ;-)
yuridichesky
62 posts in 129 days
#3 posted 72 days ago
I never made it right with pencil marking. Only when I switched to the marking knife it got better (not too much better, though).
Very nice work! Can’t wait to seeing completed project.
-- Yuri (10x4 -- yeah, that's my tiny shop!)
stefang
9435 posts in 1499 days
#4 posted 72 days ago
Excellent work Jim.
-- Mike, American in Norway
Boatman53
411 posts in 362 days
#5 posted 72 days ago
Thanks guys. I’ve tried a marking knife (not a good one mind you) and I usually end up cutting a bit of the pin or it doesn’t stay tight to the pin. I don’t do dove tails very often. The last ones I did were the big ones on the workbench last fall/winter prior to that it must be about 8 years and again they were in 2” thick teak on a new butterfly hatch for a boat of course. These little guys are small, 1/8” at the top, I had to modify some tools to get in there.
Jim
Don W
9930 posts in 733 days
#6 posted 72 days ago
nice dove tails Jim.
terryR
1103 posts in 474 days
#7 posted 72 days ago
Those look great, Jim! I am also bad about staying in the shop at night for ‘just one more’...and whatever usually comes out sloppy, too. I bet we ALL have that problem sometimes! :)
-- tr ...see one, do one, teach one...
Boatman53
#8 posted 72 days ago
I know I’m not alone. Just sharing that even with thirty years experience in wood working my excitement with the project and the lack of time (which will get crunched even more as we get closer to spring) over rode my common sense. They are easily fixed and after the box is varnished almost invisible. I do avoid tricky machine cuts at the end of a long day, no exceptions.
Jim
helluvawreck
10348 posts in 1032 days
#9 posted 72 days ago
Thanks, Jim. Nice work.
helluvawreck aka Charles
gfadvm
6600 posts in 855 days
#10 posted 71 days ago
Very impressive bandsawn dovetails! I’ve got a nice bandsaw Hmmm…...
Boatman53
#11 posted 71 days ago
Thanks everyone.
Gfadvm…. Do some practice ones on some pine before you take on the hardwood. A sharp well tracking blade is helpful also, but the cuts aren’t long so tracking isn’t that big of an issue.
Jim
