Moved blog to make on single blog
Blog entry by Blackie_ posted 06-20-2015 11:23 AM 1734 reads 2 times favorited 8 comments Add to Favorites Watch
http://lumberjocks.com/Blackie_/blog/61042
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
8 comments so far
View Jim Jakosh's profile
Jim Jakosh
20754 posts in 3158 days
#1 posted 06-20-2015 11:43 AM
Nice going Randy. Time to make dust!!!
View  woodshaver Tony C   's profile
woodshaver Tony C
6053 posts in 3406 days
#2 posted 06-20-2015 12:08 PM
Moving right along and lightning speed to say the least. Nice work all around too. Did you win the lottery? I know you must of spend quit a bit so far. Then comes your great looking projects soon!
-- St Augustine FL, Experience is the sum of our mistakes!
View Blackie_'s profile
Blackie_
4883 posts in 2565 days
#3 posted 06-20-2015 12:33 PM
Thanks Jim and Tony, actually the monies came from last years sells :)
Rick Dennington
5957 posts in 3247 days
#4 posted 06-20-2015 02:20 PM
Blackie,
Stellar job on the work bench…It looks a lot like mine, except for the cabinet system I build for underneath…I see you used MDF for the top….I would suggest putting about 4-6 coats of poly on it, as that will help “wick” away any moisture you might get on the top…Things spilled, like glue, etc. will wipe right off, plus it gives the top a nice light brown petina…..Just a suggestion….You’ve done a great job on the whole re-build of your shop…I’m impressed…..
View DocSavage45's profile
DocSavage45
8639 posts in 2895 days
#5 posted 06-20-2015 03:36 PM
Randy,
Nice! I commented on your project page about the bench. Now I see your solution.
I use Rick’s solution for my MDF projects, and plywood that’s not cabinet grade. Two coats of seal coat sink into the material and waterborne poly seals the surface.
As I said it’s looking like a model shop, and it’s going to be hard to get it dirty. LOL!
Pretty straight forward solution on the outfeed table. I have a Grizzly cabinet saw and I want to come up with an efficient and non permanent outfeed table.
-- Cau Haus Designs, Thomas J. Tieffenbacher
Rick Dennington
#6 posted 06-21-2015 03:03 PM
Hey Tom,
Thanks for the nice comment on my solution for MDF….Actually, I was thinking about it, and I left out an important step…..After the bench is built , I apply 2 coats of Watco Danish Oil (clear) before applying the poly….The danish oil will soak into the top , give it a nice petina, and when rubbed in and dry, then the poly…...
DocSavage45
#7 posted 06-21-2015 07:46 PM
Rick,
Just saw your response.
The “Danish Oil” is a formulation combining oil and hardeners ( such as polyurathane, and I believe the shellac? might be wrong here) I would use it to enhance grain in woods. I think the sealer is cheaper? LOL!
“You say Tomatoe, Some say tommato.” I just want to eat it before it gets over ripe. LOL!
Happy Dad’s day to all.
View Roger's profile
Roger
20929 posts in 2857 days
#8 posted 06-22-2015 12:29 PM
You have certainly come a long way these past weeks. It’s been a joy to follow along with you. I’m not even tired from seeing all the work you’ve done. :)
