Gone
Blog entry by Blackie_ posted 04-28-2015 08:59 PM 1374 reads 0 times favorited 8 comments Add to Favorites Watch
Gone
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
8 comments so far
View longgone's profile
longgone
5688 posts in 3302 days
#1 posted 04-28-2015 09:06 PM
LQQking better and better every day….!
View grizzman's profile
grizzman
7836 posts in 3297 days
#2 posted 04-28-2015 09:22 PM
glad you figured out your electrical problem, those can be a real pain if you don’t have things labeled, all the rest looks good, my only comment is that your opening where your AC is, the bottom plate is just one 2×4…with your unite being pretty heavy, it would have been better to have it beefed up some…I’m one to always make sure there is structural strength….just a thought….thanks for the blog update…
-- GRIZZMAN ...[''''']
View Blackie_'s profile
Blackie_
4883 posts in 2506 days
#3 posted 04-28-2015 10:19 PM
Thanks Greg and Grizz, the AC unit will have knee bracing on the outside with between a 1/4 to 3/4 drop toward the back for run off, plus that 2×4 is just under 24” sitting on two jacks and a cripple, it ain’t going anywhere :)
I have to say that retirement has made me soft, I’m not used to this kind of work, my feet and keens are taking a beating. :)
View DocSavage45's profile
DocSavage45
8545 posts in 2836 days
#4 posted 04-29-2015 12:28 AM
Randy,
LOL! I’m not the only Woosie! I’m actually doing strength training to get into shape for milling with my chainsaw mill.
Pictures of additional space looking good, and now I can see the supports in your trusses.
I checked out LED flood lamps?? Whoa! Pretty expensive. Wanted to improve work lighting. Decided to use my lamps that have a porcelain base ( used for turkey roosts in winter w infrared heating lamps ) with a 100 watt florescent. Does the job
What size ducting are you running for dust collection?
As Stmpy Nubbs says “Put your feet up and have a cool one, cause you’ve earned it my friend!”
-- Cau Haus Designs, Thomas J. Tieffenbacher
Blackie_
#5 posted 04-29-2015 01:43 AM
LEDs aren’t that pricy Tom, the cans are $8.00 and the trim kits. Are $19.00, what are you considering to be expensive?
I’m going to be running 4” pipe for the DC plumbing.
DocSavage45
#6 posted 04-29-2015 06:10 AM
Looked at LED floods at Menards ( Like Home Depot only it’s my home away from home.) 27 bucks! that was for a 75 watt LED flood. They are suppose to last longer than we have to live but????
Cans probably not so expensive, didn’t need those.
what size is your Dust collector motor?
Blackie_
#7 posted 04-29-2015 09:34 AM
I’m using the HF DC so I believe it’s 1HP
Tom, these are the trim kits I am using, not flood.
http://www.homedepot.com/p/Commercial-Electric-5-in-and-6-in-White-Recessed-LED-Trim-with-90-CRI-2700K-CER6730AWH27/204726945
View Roger's profile
Roger
20928 posts in 2797 days
#8 posted 04-29-2015 12:49 PM
Coming along Randy. Keep on truckin.
