Gone
Blog entry by Blackie_ posted 04-08-2015 10:30 AM 1828 reads 0 times favorited 17 comments Add to Favorites Watch
Gone
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
17 comments so far
View Roger's profile
Roger
20929 posts in 2859 days
#1 posted 04-08-2015 11:40 AM
WhoopWhoopWhoop!! Oh boy Oh boy!! Coming along nicely
View grizzman's profile
grizzman
7836 posts in 3358 days
#2 posted 04-08-2015 12:15 PM
things are looking great randy, i hope your weather stays good until you have the floor covered, and I’m glad to see you have a nail gun, when i built my shop and my house my nail gun sure saved my arm, i had just had surgery on my right elbow and didn’t need to be swinging a hammer for all of that work, nail guns are one of the best inventions if you ask me, enjoy the day.
-- GRIZZMAN ...[''''']
View codemonkeyww's profile
codemonkeyww
44 posts in 1481 days
#3 posted 04-08-2015 12:21 PM
Man its really coming along!
-- "Cause I know that time has numbered my days" -Mumford
View helluvawreck's profile
helluvawreck
31723 posts in 2921 days
#4 posted 04-08-2015 12:58 PM
It’s going to be a great shop. Congratulations.
helluvawreck aka Charles
View Sodabowski's profile
Sodabowski
2374 posts in 2888 days
#5 posted 04-08-2015 01:06 PM
What the guys above said. I’m curious though as to how you’ll cover the transition between the two floors, rubber expansion joint?
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View Blackie_'s profile
Blackie_
4883 posts in 2567 days
#6 posted 04-08-2015 01:24 PM
Soba, they are pretty much butting together, tight joint, so instead of calking I’m going to use my own pre made putty by using saw dust and glue mixed then sanding it smooth than I’ll come back over it with the gray garage floor paint to keep it smooth and protected.
I don’t think I have to worry much about movement, I’m not even sure if that OCB movies at all but everything is anchored down with lag screws and nails.
View Jim Jakosh's profile
Jim Jakosh
20773 posts in 3160 days
#7 posted 04-08-2015 01:34 PM
Looking good, Randy!!
View kiefer's profile
kiefer
5619 posts in 2722 days
#8 posted 04-08-2015 02:07 PM
Looking good/
Is that T&G OSB sheeting ?
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View DocSavage45's profile
DocSavage45
8641 posts in 2897 days
#9 posted 04-08-2015 04:52 PM
Randy,
Looking good. Plumb and level. Again, nice to have help. 2×4 trusses? I have been comparing OSB and plywood for a lumber and lawn tractor shed. 1/2 the price of the plywood which I’ve always used. Work safe, not like me? LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1231 days
#10 posted 04-08-2015 05:03 PM
The AC is out, the 8000 BTU AC unit was covered in dirt and dust and will be replaced with an 18500 BTU AC with heat pump.
I am not a HVAC person but that seems like a very large BTU increase for the size of the expansion. I recall “Ask This Old House” show saying that the AC should be properly sized and not oversized.
View MT_Stringer's profile
MT_Stringer
3172 posts in 3286 days
#11 posted 04-08-2015 05:04 PM
Your addition is looking great. It’s too late now, but I was thinking it would have been nice to run some electrical for an in floor receptacle for any stationary tools you might be planning to use.
Regardless, the addition is looking great.
Mike
Blackie_
#12 posted 04-08-2015 08:47 PM
Thanks all
Klaus, yes T/G 3/4 for the flooring, 7/16 for the walls and roof.
Tom the Trusses are 24 center 2×4’s
WoodNsawdust, I figured on what you are saying but…. a human body generates 600 BTU alone, plus with all of the tools and the DC sucking the cold out and also it’s the smallest 240 volt I could find, got a good deal on it, it was miss marked on the pricing at Lowes I saved $24.00 on the price.
Mike that would have been a great Idea, thanks, sure wish you have some in sooner LOL.
DocSavage45
#13 posted 04-08-2015 11:58 PM
Randy,
RE: the floor mounted electrical. You can run some plastic pipe and anchor to the floor joists and there is still time. Or maybe romex if that is allowable?
Keeps the wires out of the way?
View robscastle's profile
robscastle
5144 posts in 2259 days
#14 posted 04-09-2015 09:33 AM
Looks good, I assume the replacement for the 8000 BTU A/C is 8500 BTU and not 18500 BTU?
Power, if its still needed you could feed from overhead then down on jack chain that way its off the floor area completely, on that I am not sure of the power consumption of your machines, but you could also add an in line Isolation swith and run two machines from the one feed.
-- Regards Rob
Blackie_
#15 posted 04-09-2015 10:00 AM
Thanks Tom and Robert on the electrical ideas, my building is but only 12’ wide so in wall outlets should be OK, if I do decided to run an in floor outlet I can still do that pretty much anytime once I start the wiring.
Robert, old unit was an 8000, 115 volt it was just enough to cool the shop but now since I’m upgrading from a 115 / 120 volt the smallest in a 230 / 240 volt I could find is 18500 BTU.
I’m not sure why the box is labeled at 230 volt when I’ll have 240 volt at the outlet.
