Gone
Blog entry by Blackie_ posted 03-09-2013 10:48 PM 4952 reads 2 times favorited 17 comments Add to Favorites Watch
Gone
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
17 comments so far
View longgone's profile
longgone
5688 posts in 3363 days
#1 posted 03-09-2013 11:04 PM
Good use of your ratchet straps Randy…How are they at keeping the box perfectly square during the glue drying?
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2537 days
#2 posted 03-09-2013 11:24 PM
Hi there, I use a very similar method for gluing up my boxes. Tape the corners and use a ratchet strap to get tight glue ups. Works well for me as the tape holds the box square and any gaps are closed using the straps.
-- If you believe you can or can not do a thing, you are correct.
View Blackie_'s profile
Blackie_
4883 posts in 2567 days
#3 posted 03-09-2013 11:37 PM
Greg, they do very well, if you have your miters cut square the straps are going to hold true, this box is right on the money from corner to corner.
View JoeinGa's profile
JoeinGa
7739 posts in 2062 days
#4 posted 03-09-2013 11:40 PM
I’ve done this with frames as well. And if the frame/box is small enough, you can use bungie cords to do the same. So long as your angles are true, it’ll set up square.
View Woodwrecker's profile
Woodwrecker
4164 posts in 3630 days
#5 posted 03-10-2013 01:42 AM
Boy O boy, you aren’t going to believe this Randy.
I was out in the shop today working on a project and needed a clamp, and noticed I had a pack of those straps in the drawer. I saw someone post a “how to” on using them but never followed up on it.
And low & behold, you post this !
Thank you my friend, I’m going to break these out and use your method the next time I need a strap clamp.
(kind of tight on this end as well…:)
Thanks
View Boxguy's profile
Boxguy
2703 posts in 2322 days
#6 posted 03-10-2013 01:46 AM
Blackie,
Do they look like this?
This is a link to a tutorial about how I make them…much like yours except I eliminated the knot. The scrap piece is to keep the ratchet mechanism from digging into the wood. Looks like you are taking the challenge of fitting a lid on the top with a 45. Why not just glue it on square and bring it flush with a bearing router bit? I have used the 45 technique, but only if I am wrapping a grain pattern from back to top to front and want it all to match.
-- Big Al in IN
View gfadvm's profile
gfadvm
14940 posts in 2745 days
#7 posted 03-10-2013 02:20 AM
Randy, I use those in EXACTLY the same way you do. (Great mind think alike, huh?) I’m amazed that the boxes always come out perfectly square. I have one of those Bessey band clamps that I like as well but too pricy to have as many as I need.The Bessey came with those plastic corner thingys. Used em once, hated em!
View Monte Pittman's profile
Monte Pittman
29570 posts in 2393 days
#8 posted 03-10-2013 02:28 AM
I am with Andy. I do it the same as you.
Blackie_
#9 posted 03-10-2013 02:56 AM
Big Al, you are speaking Greek to me remember this is all new to me, I’m just now coming into a new world of box making other then bandsaw boxes.
The reason I am doing it this way is because this is how it was demonstrated to me during one of my local woodworking meetups from a 40 year woodworking veteran, I didn’t ask questions I just watched how he did it.
longgone
#10 posted 03-10-2013 05:18 PM
Randy…that is a good way to glue your boxes. I have a dozen of these frame clamps that I bought several years ago and they work great….I have a lot of those strap clamps that I bought for use with my flatbed trailer and never thought of using them for box glue up before I bought thew frame clamps. It would most certainly been cheaper than the frame clamps but I don’t have any complaints at all about the ones I use now other than the initial cost.
View Dark_Lightning's profile
Dark_Lightning
3171 posts in 3164 days
#11 posted 03-11-2013 01:38 AM
I have both the Bessey clamp system and another called “Pony”, which I can’t recall where I purchased. The “Pony” has metal corners, which only work if you have already radiused the corners. Kind of hard to do on an unfinished glue-up. I’ve used the “Pony” on boxes as small as 6” by 2.5”. Kind of a clumsy setup, what with the 6 foot strap. I’m hesitant to chop it down, as I always like my tools to span their capability, though I may never make anything that big.
Blackie, it appears that you even mitered the top edges of the sides. Do you plan to glue the lid on and then slit the top off the box?
-- Random Orbital Nailer
Blackie_
#12 posted 03-11-2013 04:52 AM
Hi AtomJack
To answer your question, yes, I’ve already done just that though I am still in the learning stage, I’ll try just gluing the top on straight without the 45s next.
gfadvm
#13 posted 03-12-2013 12:38 AM
Randy, The mitered top you are doing is more difficult than just glueing a board on the top of your box BUT it is a much cleaner/classier look as there is no end grain or long grain glue joint visable. Brit Boxmaker’s EZ Mitre technique is a good example of the look achieved by mitering the lid. You can “flow” the grain right across the lid and down the sides or front. I’ve done it like you did as well as using the EZ Mitre technique. I really like the look!
View WorstNicknameEver's profile
WorstNicknameEver
2 posts in 1950 days
#14 posted 03-21-2013 03:55 PM
I am a newbie and I was wondering if any one has used these straps for a simple edge to edge glue up. Something like a table top? I have a number of straps but very few long clamps? The straps would be easier to store and I like the fact that they can have more than one use!
Blackie_
#15 posted 03-21-2013 11:54 PM
WNNE I’m not the one that can answer that question sorry, hopefully someone here can, might try asking in the forum this question and link this post in your posting.
