For those of you that do a lot of small project glue-ups, and didn’t already know this, by laying a sheet of wax paper under your projects it makes clean up a breeze and no longer scraping glue off of the work surface. Wax paper peels right off of your project as well, it works great for calls when placing them between your clamp and project it keeps the wood from gluing to your projects.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
15 comments so far
woodshaver
home | projects | blog
1995 posts in 1519 days
#1 posted 263 days ago
Great idea Blackie! I use wax paper all the time under my bar clamps. Keep the glue off and so I don’t get the black spot’s on the wood where the glue touches the metal bar.
-- Tony C , My high school shop teacher said "You can do it"... Now I can't stop!
AJswoodshop
1038 posts in 442 days
#2 posted 263 days ago
Great tip! Some of my clamps are metal C-clamps, which can dent your wood. Thanks for the tip!
AJ
-- If I can do it.....so can you! -AJswoodshop
86945 posts in 1743 days
#3 posted 263 days ago
It works very well
JR45
405 posts in 478 days
#4 posted 263 days ago
Good idea. Teflon baking sheets do the same job and they are reusable as well.
Jim-
-- It always looks better when it's finished!
Bertha
13111 posts in 859 days
#5 posted 263 days ago
I use wax paper to squeeze glue onto when using an acid brush. I hadn’t considered other uses. Thanks for the post!
DaddyZ
2000 posts in 1206 days
#6 posted 263 days ago
Use it all the time Clamping up boards !!!
Monte Pittman
7040 posts in 504 days
#7 posted 263 days ago
Simple solution. Great thought.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
JAGWAH
924 posts in 1250 days
#8 posted 263 days ago
For small projects great idea, but I buy rozen paper from the lumber yard and hang a roll like paper towels at the end of my bench. I just pull a run across the bench and glue away. It also works as a surface to scale draw a project.
Another handy is when you see any of the refrigerator boxes. Just cut the sides apart and use them for a bench topper when your going to be a bit more rough than usually.
-- ~Just A Guy With A Hammer~
Roger
9191 posts in 970 days
#9 posted 263 days ago
Yep, Blackie. I’ll lay a piece or tape a piece on my pipe clamp where the glue will squeeze out. Works very well. If you poly your work top, glue won’t stick to it either
DocSavage45
2854 posts in 1008 days
#10 posted 262 days ago
Anyone know if other than rosen paper we can get wide rolls of waxed paper?
-- Cau Haus Designs, Thomas J. Tieffenbacher
Toolz
885 posts in 1908 days
#11 posted 242 days ago
You can get “freezer” paper in rolls wider than wax paper. It has a plastic coating on one side. That is what I use.
Larry
-- Larry "Work like a Captain but Play like a Pirate!"
Dave Dye
4 posts in 482 days
#12 posted 242 days ago
I use a Melalmine top on the table that I do glue-ups on. Glue doesn’t stick to Melamine.
-- Dave Dye
Grandpa
2380 posts in 841 days
#13 posted 242 days ago
I also have Melamine on my assembly table for a top. I like it. It helps old eyes find things in the light too. I have good light but ….well, older poeple just need a little more. When my table top gets ugly and stained, I turn the top over and start fresh.
Mip
232 posts in 244 days
#14 posted 242 days ago
These tips work very well, I use them all the time. Another thing you can use waxed paper for is lubrication. Since there is wax in waxed paper(duh!), you can rub it in you miter gauge slot on the table saw if the gauge sticks. Just rub it anywhere it needs a small amount of lubrication.
Blackie_
1645 posts in 678 days
#15 posted 241 days ago
Yep Mip I use it also for that same purpose as well.
