Shop Made Screwdrivers Without a Lathe
Blog entry by BigRedKnothead posted 01-28-2014 08:17 PM 5102 reads 16 times favorited 33 comments Add to Favorites Watch
A couple of LJs have done this already, but they all used a lathe. The only part of a shop made screwdriver handle that needs to be round is the “tenon” in order to fit a proper ferrule. I had the notion that a tapered plug cutter could be used, and I was right.
With that obstacle conquered, and a batch of screwdriver shanks from Lee Valley Tools, I went about making my custom screwdrivers.
There are pictures of each step, so that should help. I made several extra handles and tried the next step on those extras along the way. Basically, I was just wingin’ this;-)
Here’s a start. The shanks, some 1/2” copper pipe cap fittings, and some burled walnut cutoffs. I ripped all the blanks to 1 1/8” square.
I smoothed the four sides of the blanks, hoping it would save some sanding later.
You’ll want to leave the blanks long while you round over the corners. It’s safer. I used a 3/8” round over. Then I cut them to length with a crosscut saw and bench hook. The believe the large size three were 5”, med. 4 3/4”, and small 4 1/2”.
Here’s my gypsy rig for drilling the tenons. I’m using a 5/8” tapered plug cutter. Works pretty well. You have to start very slow or it will jump on end grain. Since there is no way to “center” a plug cutter per say, you just have to fuss with your setup til you get it right. Another reason to mass produce these if your going to do it.
Also, this is really the only part I goofed on. I drilled until the plug cutter bottomed out. I should have used the stop on my drill press. My tenons ended up a little long and fat toward the base, which I had to correct later.
Then I used a 1/2” bit to round over the butt end of the handles.
I marked the centers to be sure. Then, using the same jig, I drilled the holes for the shanks. These must be drilled straight, or you’ll have one crappy screwdriver. The shanks are a couple different sizes. See what you’ve got. I drilled them all just one bit size(1/64) bigger than the actual shank. Also do some figuring to see how deep to drill.
Not being confident in my hand saw skills, I scored the shoulders of the tenon on the tablesaw.
A hand saw was needed to get the last of the little corners.
To begin the shaping. I used a block plane on the four corners, tapering them toward the tenon. This gave my big red guns a workout.
Time for some ferrules.
These are the only thing that will keep your wood from splitting when you drive the shank home. Lee Valley sells some brass ones. That would have been easier, but I really like the looks of copper….so I made my own. Not too hard to do. I paid $10 for a bag of twenty-five 1/2” copper pipe end caps, and drilled them. Another goofy setup. PSA sandpaper is needed to keep the fitting from spinning. And there’s a recess drilled in the board below. I really could have used a drill press vise.
I didn’t always get the hole centered as I would like. I cleaned them up with a file. Carefully. They’re friggin hot right after you drill them
As I said before, my tenons were a little over-sized. I trimmed the length, then conceded to the power sander. I swear that machine was created my Lucifer himself.
I would probably be wise to epoxy the ferrules on first, then drive in the shanks. But I’m a nutjob, so I did both at the same time. The friction fit of the ferrules held pretty well anyway.
Pay careful attention when you start driving the shank, if the “wings” on the shank start biting into the wood crooked, doesn’t matter how straight your hole is drilled….they’ll end up all cock-eyed. This was the best way I could come up with. Once they’re started straight, your good. I drove all but the bigger slotted or flat-head screwdrivers. You’ll see why in the next step.
Who needs a Lathe? I’ve got a drill press!
The shank of a flat-head screwdriver will not fit in my chuck. So I sanded them by cutting the head off a lag bolt and threading it into the wood. I started shaping them with a file to knock the big corners off.
Then a lot of sanding. I worked from 80grit up to 600. You can seen in this pic how all the rest of the screwdrivers could be chucked in the drill press for the rest of this saga.
After sanding on the drill press, I had to take them over to the bench and sand the flat sides by hand. I finished with a couple coats of danish oil. Then paste wax. I also used some very fine grits on the copper and chrome shanks. I just like the way it looks.
There you have it:
Overall, I’m pretty happy with them. They fit my big ol’ mitts nicely. The shaping isn’t completely uniform. But not band for some of the first tools I have ever made, And hey, they weren’t made my a CNC machine. I made ‘em. You should too;-)
Take care knuckleheads. Questions and comments always welcome, Red
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
33 comments so far
View lepelerin's profile
lepelerin
495 posts in 2321 days
#1 posted 01-28-2014 08:32 PM
well done
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2102 days
#2 posted 01-28-2014 08:40 PM
Fantastic. Thanks for posting.
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
View jumbojack's profile
jumbojack
1676 posts in 2620 days
#3 posted 01-28-2014 08:41 PM
Very inventive. They look great! No boredom at your house.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3581 days
#4 posted 01-28-2014 08:45 PM
You made a great job of them, and they look handsome too. However a lathe would have been a big help i.m.h.o anyway well done. Alistair
View Don W's profile
Don W
18710 posts in 2563 days
#5 posted 01-28-2014 08:48 PM
excellent!!!!
View lightcs1776's profile
lightcs1776
4200 posts in 1650 days
#6 posted 01-28-2014 08:56 PM
Sharp looking screw drivers. Nicely done.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View CFrye's profile
CFrye
10189 posts in 1835 days
#7 posted 01-28-2014 08:59 PM
You really did a fine job with that burl Red! Blog is great too. Thanks for sharing.
-- God bless, Candy
View JADobson's profile
JADobson
1034 posts in 2107 days
#8 posted 01-28-2014 09:08 PM
Like, all your work, they look fantastic.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany
View widdle's profile
widdle
2069 posts in 2994 days
#9 posted 01-28-2014 09:13 PM
Those came out good..Got to try that soon..
View lateralus819's profile
lateralus819
2241 posts in 1885 days
#10 posted 01-28-2014 09:29 PM
Excellently done Red. I think i may have to give this a try.
Another trick that i’ve done for making tenons is to figure out a starting diameter of a blank.
Let’s set 1 1/2” x 1-1/2”. Pick up a 1-1/2 forstner bit, a block big enough to drill into. I use a 3” x 3” block.
Drill a whole with the aforementioned forstner bit. The 1-1/2” x 1-1”2 blank should fit into the whole, and spin freely, use a little wax if need be.
Now orient the block so the whole is horizontal, and mount a router on top, with the bit protruding over the side, so when you move the blank through, it removes material. Keep adjusting the bit depth until the desired length/width of tenon is achieved.
I leave my tenons a little long and smaller so i can chuck it in the press and sand and shape as necessary.
I used this twice to make mallet handles. Works great.
View TerryDowning's profile
TerryDowning
1077 posts in 2113 days
#11 posted 01-28-2014 09:36 PM
Nicely done Red.
I have that very same sander. I got it as gift many years ago. Lucifer himself indeed!! Unfortunately, it won’t die no matter how bad I treat it and it does do a decent job for what it is.
-- - Terry
View Douglas's profile
Douglas
424 posts in 2556 days
#12 posted 01-28-2014 09:44 PM
Ah, yes, fancy pants screwdrivers. I dabbled in a few eBay auctions for some perfect handle ones, and also thought about these LV screwdriver shanks. Very nicely done. A mini lathe is on my list of tools for he spring, so I might go that router. Well done!
-- Douglas in Chicago - https://dcwwoodworks.com
View woodcox's profile
woodcox
2030 posts in 2008 days
#13 posted 01-28-2014 09:45 PM
Nice work Red! 5/8” cutter then sand to fit ferrule? 1/2” cutter would have been to small for ferrules because of the taper? Seems like a great price for a set of hardened tip shanks.
-- "My god has more wood than your god" ... G. Carlin.
View bondogaposis's profile
bondogaposis
4723 posts in 2347 days
#14 posted 01-28-2014 10:04 PM
Well done, nice matched set.
-- Bondo Gaposis
View Hammerthumb's profile
Hammerthumb
2844 posts in 1971 days
#15 posted 01-28-2014 10:28 PM
Knuckleheads? We resemble that remark! Well done Red.
-- Paul, Las Vegas
showing 1 through 15 of 33 comments
