I’m really enjoying this site, and I thought you all might like to see something a little different and what it takes to build a small yacht tender.
Boat building is totally different from cabinetmaking, as nothing is square, everything is on different plane, and it takes some practise to learn to make compound curves that are pleasing to the eye. We call it a ” fair” curve.
This is a 10 ft yacht tender that I built for a friends sailboat. I also made them a ships wheel and some otjher goodies.
The plans are from around 1932. I found them in an old book. First you “loft” the lines. That means to take the designers plans, and draw them full size so that you can make patterns and then molds, from which the hull is built .
Basically it’s like the old connect the dots drawing that kids do. You take a piece of plywwod and draw a grid. The ” offsets” are the designers points expressed in ft/ inches/ and eights. So a notation from the table would say 8-10-3, which means 8 ft, 10inches and 3/8”. You put a point on the grid and drive an icepick in it. Then you bend a batten around it and draw a line. They call it “lofting” because in the old days the only flat wooden floor in a boat shed to draw on was in the loft. From there you pick up patterns.
Here is what it looks like:
The plans.
A thin piece of plywood is slipped under the pointers and drawn on the pattern.
You now have half of the mold and you make a full size mold like this:
The full set of templates are pattern routed onto plywood for the full size mold.
I built a level strong back to build the hull on and set up the molds. The hull is built upside down.My workbench is perfectly flat, and ensures a level strongback.
The completed mold .
Strip planking started.
The hull is made of Honduras Mahogany and Alaskan Yellow Cedar. It is covered with 6 oz cloth and epoxy
follwed by ten coats of UV varnish. I hope you enjoyed something a little different
The completed yacht tender.
Hull #2
13 comments so far
Thos. Angle
home | projects | blog
3949 posts in 714 days
posted 238 days ago
WOW!! that’s some pretty work.
-- Thos. Angle
DaveR
1044 posts in 472 days
posted 238 days ago
Finastkind. Very lovely little boat. Do you know who drew the lines?
I’ve been trying to decide on the next boat. I think the list is getting longer; not shorter.
-- Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
BigBob
59 posts in 240 days
posted 238 days ago
The lines are in John Gardners book BUILDING SMALL CRAFT. It is the Lawley Tender.
DaveR
posted 238 days ago
Ah, yes. I thought it looked familiar. Thank you.
Dave
thetimberkid
1945 posts in 454 days
posted 238 days ago
Wow, great job!
Thanks for the post
Callum
Bob42
271 posts in 541 days
posted 238 days ago
Beautiful!!
Great job.
-- Bob K. East Northport, NY
woodworm
5811 posts in 342 days
posted 238 days ago
Very interesting blog post.
Agreed with you that boat building is different from cabinet/furniture making. It has different level of painstaking. You have to have higher conciousness that you have greater liability & responsibility to fullfilling your customer’s satisfaction, cos you are dealing with his safey as well.
Great job and good luck!
-- Regards, Woodworm - KL, MY.
sis
7 posts in 228 days
posted 226 days ago
Bob, I’d like to build the 9’ Lawley Tender. Could you possibly send me a readable copy of the plans or tell be where I can buy them(besides in the gardner book?
thanks, Sis
Blake
2560 posts in 626 days
posted 225 days ago
Wow, gorgeous. I love the progress photos of the lofting process.
SCOTSMAN
1617 posts in 336 days
posted 225 days ago
absolutely beautiful workmanship.To my poor eyes it looks longer than ten feet. I would have thought twelve to fourteen ,well done again .Now can you make an old Sctotsman one around one hundred and forty feet with cabins a funnel and acanon a jolly rodger flag and an all female beardless crew LOLAlistair
sis
7 posts in 228 days
posted 224 days ago
Bob I got the book—It only had the 12’Lawley tender or the Lawton 10’.. So I’m going with the Herreshoff 10’ Pram. Wish me luckI I’m going to set it up as a sailor with a centerboard, so the bottom will be altered.
Sis
PetVet
189 posts in 239 days
posted 224 days ago
As a sailor, I really appreciate you sharing this with us. There is something so intrinsically beautiful about wooden boats.
-- Rich in Richmond
sis
7 posts in 228 days
posted 223 days ago
Bob, I tried sending an email tothe person you recommended and it wouldnt go through (for you to send the photo copies of the Lawley 10’ tender) I got the book, but the lawley seems to be 12’. any suggestions?
thanks, Sis
