Downstairs Built-ins Extravaganza! #8: Time to stock up on sandpaper!
Blog entry by BethMartin posted 210 days ago 349 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 7: Making up for lost time. Part 8 of Downstairs Built-ins Extravaganza! series Part 9: Figuring out staining »
Okay, I am done cutting wood for a while. I’ve had about enough of that! Time to start sanding and staining so all these pieces of cabinets are out of the way and I have room to work on more parts. There is wood everywhere!
Here is what I finished up today…
This is the casing for the upper shelves that sit atop the drawers. It is ginormous! So I’ll be staining it before I glue it all together. This is the back of it facing up. The hardest part was fine-tuning the joints so that it all fits snugly. I was carrying those big doubled up shelves back and forth to the garage and they are heavy! I’m looking pretty buff now from the workout I’ve been getting.
This is the molding for the top with a little slot for the rabbet on the plywood. The molding that I’m using on this thing is simply a 45 slice off the corner of a board. I wanted very simple lines on this thing. (I know I need to sand out those saw marks. My saw is really wonky.)
And the molding to go on the bottom. (Don’t mind all the loose pieces, nothing is attached yet.)
So sanding questions…
OMG I have so much sanding to do. I already have a little palm sander – will that suffice? Or should I do it by hand with a block? What grits should I be using? I need to make a run to the store and get a ton of this stuff. While I’m doing all the sanding I’ll be making up some test boards with the finish. I seem to have a lot of scrap lying around!
Thanks for looking!
-- Beth
10 comments so far
17211 posts in 477 days
posted 210 days ago
Hi Beth
Looks like things are moving right along. As far as sanding goes at least a Random orbital sander will make things a lot easier than just a pad sander(a sander with 1/4 sheet of sand paper that just moves back and forth)If you buy one the type that has hook and loop (velcro) disc are easiest to change the sand paper.
On hard wood (not plywood) start sanding at 60 grit for Farly rough surfaces and work your way through finer grits of sand paper in this order 60,80,100,120,150,180 you can go even finer if you wish but be careful because the finer you go the more it seals of the wood from finish. In time you will know when you can start at a finer grit than 60. It’s best to parctice on some wood before useing a new sander on your built ins.
Hope this helps.
Jim
View lew's profile
lew
4515 posts in 655 days
posted 210 days ago
Listen to Jim, he has it right!
If you are going to continue to do wood working, a random orbital finish sander will become your friend! I wish I had purchased the type with hook and loop system when I started but I opted for the for the sticky, pressure sensitive adhesive type. The sanding disks were cheaper. The problem is that often you don’t “use up” a sanding disk before needing a different grit. A used disk never seems to stick too good the next time.
View rtb's profile
rtb
686 posts in 613 days
posted 209 days ago
Beth, Jim & Lew are right on the money. with hook and loop you can change sheets and still reattach without any problem. This is so useful that its worth it to go for one of the better brands and not some cheepie (B&D) also consider features like variable speed. its worth the investment. Also keep dust control in mind and wear dust masks, over time sanding dust can kill you !
View robbi's profile
robbi
171 posts in 855 days
posted 209 days ago
I agree with all of the above and also think your project is looking pretty darn good!!
-- robbi-Yadahooty!
View John in SD's profile
John in SD
118 posts in 713 days
posted 209 days ago
Well, I guess if you are determined to sand all the saw marks away…....their right…..But I think I would start with a good scraper….and maybe even end with it too!!
-- Life used to be soooo much simpler!!!!
View BethMartin's profile
BethMartin
107 posts in 278 days
posted 209 days ago
Okay, I’ll be off to the store today to look at sanders and get sandpaper. But now I’m all intrigued by John’s suggestion. I didn’t even realize that scraping was an option, but I just googled it. I’m not sure what would be easier for me – but I do hate sanding! If anyone wants to chime in more about scraping, or give me some good links, I would like know more. Thanks!
-- Beth
View Woodhacker's profile
Woodhacker
1145 posts in 623 days
posted 209 days ago
Beth, I agree with the comments above, but I’m concerned about using that technique on the plywood. If you sand through that many different grits, there’s a good chance you could sand through the finish layer of veneer on the plywood. For the plywood you might consider starting with 100 or 120, then go straight to 180 or 220, depending on how dark you plan to stain the unit.
-- Martin, Kansas
BethMartin
posted 208 days ago
Woodhacker ~ that’s a good point. And I like your advice because it’s easier. :) I will be doing test boards too, so I’ll be able to see what works and what doesn’t.
-- Beth
View CessnaPilotBarry's profile
CessnaPilotBarry
1292 posts in 602 days
posted 208 days ago
When sanding before staining, hand sand with the grain using the last grit you used with the ROS. This should remove any swirl or cross-grain sanding marks that will be emphasized with pigment stain.
If you’re using an oil based stain, a quick wipe with Naptha will show any left over swirls, so you can correct them before you stain. With a water based stain, do the same with denatured alcohol.
Scraping is a fantastic skill, one well worth learning. Be aware that scraping does have a learning curve, including sharpening skills. This curve is greatly shortened if you can find some local help to show you what a properly tuned scraper can do, how to tune it, and how to use it. I struggled for years to get a scraper to operate correctly using books, magazines, and the web. A half an hour in a hands-on class had me making lacy shavings.
If you’re staining the wood, I really doubt anyone can tell a properly sanded surface from one that’s been properly scraped.
What are you using for stain and a clear finish? Certain combinations act better stopping at certain sanding grits. In some cases, more sanding is not better.
Good on you for planning test boards.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
CessnaPilotBarry
posted 208 days ago
I forgot to mention…
Regardless of scraping or sanding, watch the edges and profiles. Nothing ruins a look like convex or concave flat parts and not-so-crisp profiles, due to overzealous sanding or scraping.
While you do want to “break” the edges, which is a fancy term for a very small round-over done with a sanding block and very fine paper or a block plane, try to evenly prepare all surfaces for finish. The “broken” edge helps the finish flow out as it dries. This prevents the clear finish from “fattening” along the edge, as well as making the edge more durable to life’s bumps and nicks.
