COASTERS #2: Illusions using Rhombus
Blog entry by BertFlores58 posted 01-28-2016 01:26 AM 1220 reads 2 times favorited 6 comments Add to Favorites Watch
« Part 1: The Conversion from Scrap to Workable Stocks Part 2 of COASTERS series no next part
Varying Designs
Using Sketchup, I had drawn a lot of possibilities for a 12 Rhombus combinations. Here is the photo of the one I like…
Cutting the rhombus.
Then, next step is cutting the rhombus. I set my compound saw to 30 deg then cut so many pieces one by one. Thanks for Daddy (Dad-in-Law) who also helped in cutting them. I could not find a photo..
Assembly
Sorting out according to colors and blend will shorten the time. Also the correct thickness will save time.
Gluing technique: I use a transparency (scrap from the office because it is not printable type but only for copying machine..zerox) underneath so the glue will stay in place and will not be dripping. The transparency will be very easy to peel off when dry.
Sanding
I make a jig to hold the coaster in place… I have only two hands that are required to control the sanding using an angle grinder. I set the speed to the lowest but the torque is affected. This is nice experience. I started using a power tool…. Doctor reminded me not to use grinder. Okay I have to be careful and therefore two hands are used. Thanks for the jig I made. It helps a lot.
This is the jig…. the rubber is strong enough to clamp the coaster. It is quick and easy to use. No screw to tighten.
Varnishing
I use sanding sealer and spar varnish for two coats. Sand in between with 1000 grit.
FINAL DESTINATIONS
I have made a lot… batch by batch. The first group that I finished was for Christmas gift. Around 160 pieces of coasters been sent out. Agnes has packed out 4 pieces per gift. They love it. One set of 4 pieces been had travel to Amsterdam. She loves it very much. BTW they are all free. About 5 sets of these have been inside the escabaƱa box and also a gift to my special friends.
My only consolation in making these coaster is the joy and happiness that the receiver had. They love the gifts considering that those were made from labor of love.
I still have stocks for the next batch.
Till next. Have a nice day.
-- Bert
6 comments so far
View Mark Wilson's profile
Mark Wilson
2123 posts in 1058 days
#1 posted 01-28-2016 01:45 AM
It’s fascinating to watch you work, Bert.
Question: How do you get a screen shot from SU into a Blog?
-- Mark
View BertFlores58's profile
BertFlores58
1697 posts in 2916 days
#2 posted 01-28-2016 01:53 AM
Mark,
Under file dropdown menu select export to 2D then save it. It will be saved as .png image. LJ accept this via insert image. Enjoy it.
-- Bert
View shipwright's profile
shipwright
7980 posts in 2792 days
#3 posted 01-28-2016 04:20 AM
Classic parquetry Bert, nice work!
View Frustrator's profile
Frustrator
87 posts in 1044 days
#4 posted 01-28-2016 08:49 AM
My english isn’t that good so excuse me if i missed something..But is it all made out of narra?
BertFlores58
#5 posted 01-28-2016 11:13 PM
Frustrator,
Not all, though I have different blend or color of Narra in there. That is why sorting out will take some time. Narra has 3 blends… yellowish white, normal brown, the dark brown, red and nearly black or purple (very rare). I got plenty of recycled narra parquets of 2×6 inch however I cannot sort out without planing it.
There are some wood in the Philippines that can I used for the black: ipil, red lauan, ebony or kamagong, dao, etc. you can search this wood in google and you will have the scientific name.
-- Bert
View stefang's profile
stefang
15881 posts in 3329 days
#6 posted 02-01-2016 12:15 PM
Great work and I loved your simple but effective jig.
