Musical Instruments Restoration #4: Bandurria Picolo Progress
Blog entry by BertFlores58 posted 07-01-2013 05:44 AM 1798 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 3: Bandurria - Key of E Part 4 of Musical Instruments Restoration series Part 5: Violin 2 - The Jig for the ribs »
Here I am back with the restoration of the Picolo (Soprano).. This is the continuation of this blog.
Last Saturday and Sunday, I made a big progress giving attention to the back plate and assembly. Here are the photo and some of my important notes on them.
The back plate with the supports and ribwork. Not to many clamps were used here.
The back plate completed.
In order to add more strength on the front plate (soundboard), support been added. I hope this will not affect the sound quality.
I had fabricated the tail piece from aluminum sheet. A cut a curve from a wood strip and then inserted the folded aluminum sheet then hammer it to form the end of the body. What is missing is just the holes for the string. I will drill it later as the distances of the holes will depend on the bridge.
Mounting and clamping the two plates. Please note that there are only two points where you can clamp.
Note that I have to fit in (not glued yet) the rims to have perfect alignment of the front and back panel.
So this is it for today though I also made the fretboard from kamagong and have not cut the grooves of where the frets are installed.
Till then. What is left here is the fretwork then the rims to be glued.
-- Bert
5 comments so far
View DocSavage45's profile
DocSavage45
8642 posts in 2898 days
#1 posted 07-01-2013 08:33 AM
Thank you for taking us with you on this journey.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View littlecope's profile
littlecope
3071 posts in 3557 days
#2 posted 07-01-2013 10:19 AM
Interesting Blog Series Bert… Very Ambitious of you to take on all this repair and restoration work!
I marvel that you can take the instruments apart so cleanly! If it were me, the parts would all be destroyed…
View BertFlores58's profile
BertFlores58
1698 posts in 2978 days
#3 posted 07-01-2013 10:39 AM
Thomas,
Thanks for reading it and joining my journey. To think of the others who really are on business with woodwork… they may not like the way of restoring because it is really a tiresome job. If only, I need one of the musical instruments… I can easily buy some disposable one… made of plywood and many cheap materials. I just hope, I can finish all these and post them as a project. Sharing with you all is a nice thing. In my case, my knowledge came out from you too.
Mike,
I was surprised…. your avatar changed. I thought a new member until I realized that it was you littlecope.
Luckily the glue that they use is somewhat no longer strong. There are some portion that are split and need to be replaced. Thanks for looking at it.
-- Bert
DocSavage45
#4 posted 07-01-2013 05:19 PM
Bert,
Love that orange clamp! :>)
View stefang's profile
stefang
15881 posts in 3390 days
#5 posted 07-01-2013 07:17 PM
Another great project Bert and interesting to follow.
