Tumbling no longer Thumbling.
Blog entry by BertFlores58 posted 04-02-2013 12:30 AM 1374 reads 2 times favorited 1 comment Add to Favorites Watch
I do accept that it was a mistake to say Thumbling. It sounds the same…. here is the beautiful look after the miter joint (Martyn … Thanks for the technique). Apparently, there were two obvious mistakes I have done:
1) the bevel cut (90 deg) using a portable router was overcut creating a thorough cut that even the masking tape underneath was cut. It is not that the router was adjusted wrongly but the wood board uneven thickness. It is still good.
2) the top is slightly uneven, it is better to hinge this lid because you cannot rotate the lid as it will not fit.
Till next time.
Thanks for viewing.
-- Bert
1 comment so far
View Grumpymike's profile
Grumpymike
2214 posts in 2218 days
#1 posted 04-02-2013 06:08 PM
Egads man, I wish my mistakes looked as good as yours.
This is turning out to be a wondreful piece … Looking forward to seeing the finished product.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
