CYLINDER MAKING #7: Progress on Stacked blocks Cylinders
Blog entry by BertFlores58 posted 04-02-2013 12:11 AM 1227 reads 1 time favorited 0 comments Add to Favorites Watch
« Part 6: Blocks stacked together Part 7 of CYLINDER MAKING series no next part
Here are some pictures after taking out masking tape and regluing the gaps.
This is the plastic lid that became the template for the circle.
After regluing the gaps… It is still obvious that some gaps are not yet fully filled up.
Still thinking of the best method of filling up the gaps….
(Martyn [Britboxmaker] suggested to use Black epoxy for these as they will also add highlight to the design…. Take it from the expert, why not…) My purpose is to make it strong first then do the top and bottom so I can sand the cover and cylinder at one time.
I would prefer to make the bottom and top first.
Sanding will be done on the sides.
Regret that I can do only on Saturdays because of office works…
Till then…
-- Bert
0 comments so far
