Tumbling blocks variation
Blog entry by BertFlores58 posted 03-30-2013 04:42 PM 1434 reads 2 times favorited 4 comments Add to Favorites Watch
Have you ever tried a square that becomes a diamond when a shadow is cast on the corner side… an illusion by discovery.
I was recycling small pieces that are kept for future use. Here is what I was able to make…
First I made those irregular ones into a square using only a miter box. Cutting the sides equally gives a better way of repetetive sawing making a square. Without changing the position of the stopper, as long as there is enough area and one portion is straight then a square can be made by cutting it repeatedly on 3 corners.
Those pieces that are not enough to be a square, I made it as a strip whose ends are mitered for a 90 degree joint (45 degree cut). These I need two colors. The NARRA and the White… Using these, I was able to come with these….
The one on top was just a square and glued together with a strip of white border.. here is a close-up view.
Look at the side and you will find out the cut pieces how it was formed.
And the other one….
Have you checked your eyes? Those acacia (brown) are not rhombus but just square…
This will become a mitered box with sides that gives me a puzzle how to join….. watch for it.
That will be for now…. a lot of scrap recovery projects ongoing here…
Thanks,
-- Bert
4 comments so far
Todd A. Clippinger
8901 posts in 4068 days
#1 posted 03-30-2013 04:51 PM
That is definitely cool!
View jap's profile
jap
1251 posts in 2023 days
#2 posted 03-30-2013 05:04 PM
that’s awesome!
-- Joel
View Sheila Landry (scrollgirl)'s profile
9222 posts in 2888 days
#3 posted 03-30-2013 06:15 PM
It is good to see you here Bert! You always have such interesting and detailed posts. Thanks again for sharing what you have learned with all of us. You are an inspiration to all of us!
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View JoeinGa's profile
JoeinGa
7735 posts in 1976 days
#4 posted 03-30-2013 06:51 PM
It makes me dizzy just looking at it!
Pretty cool!
