Additional to these Narra parquet boxes is an experimental Aluminum framing on the lid plus division and tray. It turned out good. I have not finished yet the finishing and the lid handle so please bear with the raw unsanded pictures of the box… I just want you to see it prior finishing it. You can still spot the errors.
The challenges…
Gluing the parquet pieces…. I have to make a 3 inches wide from this parquet so I added both half inch strips on the side of a 2×2 parquet.
The lid is done perfectly fitting overlap with Aluminum frame brass plating… find hard to look for the proper glue but in the end it was my PVA used for wood that stick good. Cut the miter with my miter saw with a blade that is for aluminum.
The dovetail… though this is not my first.. it took me a more time to figure out how will I cut the inner portion of less than 1/8 inch pins opening. Well, I use a coping saw that works alright.
The trays and divisions…. I have to use a thinner narra parquets…. This time I use 5mm thick. Just normal.
The tray bottom board is a very strong wood… (MOLAVE).
As you can see… the greatest challenge for this box is to finish it. Sanding … I have to prevent contact with the aluminum framing. The varnish to be used and final coat. The lid handle or know will also be a challenge.
Some other pictures:
THE BOTTOM…
THE SIDE ….. Look how the a-framing fits snugly on the box. Maybe I will have a problem when I apply the finish as it will widen.
Till next..
-- Bert
7 comments so far
lilredweldingrod
home | projects | blog
2498 posts in 1278 days
#1 posted 631 days ago
Hey Bert, I like what I see so far. The parquet lid is very interesting. I’m looking forward to the finished box.
Bill Davis
217 posts in 2095 days
#2 posted 631 days ago
Beautiful Bert!
Cozmo35
2138 posts in 1207 days
#3 posted 631 days ago
Nice!
-- If you don't work, you don't eat!.....Garland, TX
Armand
189 posts in 1082 days
#4 posted 631 days ago
Nice Bert..can’t wait to see the finished box.
-- My Master is Mankind's Greatest Carpenter.
12067 posts in 1512 days
#5 posted 631 days ago
always moving into new worlds bert
and well too
look forward to the finished box
littlecope
2334 posts in 1673 days
#6 posted 630 days ago
You’re a Box-making Machine Bert!!
Picture-perfect Dovetails, and I like the Aluminum idea…
Is that one piece, formed and cut to fit?
Great Job my Friend!!
BertFlores58
1537 posts in 1093 days
#7 posted 630 days ago
Thanks Mike,
Actually that frame is also recycle angle bar or you may say an L-bar brass plated. I cut the corners in miter saw being sandwiched by two wood splits to avoid a tearout and easier control. I saw this technique with those framing shops. The secret in measuring the exactness in cutting the dimension from inside face otherwise the cut will be short. Well, like they said… practice makes perfect.
-- Bert
