Actually, I still have so many pending designs such as spiral, rectangular and the parabolic that are on halt.
However, when I experimented on this rhumboid …. that from a square rod, I can convert it to a 60×120 degrees rhomboid. Simply saying, I can create two equilateral triangles out of a square cut 45 degrees from end to end. Meaning 45 on x axis and 45 degrees on y axis of a miter.
Here is the design:
THE CONSTRUCTION..
And here is the latest photo of the project after several extraneous cutting. I welcome all the critics and questions that I can answer I know how difficult it would be but it is a reality. The size of the board is about 16×22 inches (just edited it from 16×42 which is wrong) [Thanks for Steve]. I never had counted how many pieces..
A soon as I have the latest photo I will post an update.
Please note that I am dedicating these to all my mentors here in LJ. Most special are Martyn, Spalm, Larry and even who is not so active these days GaryK. I like to try what my hands can do with respect to what this experts have made.
-- Bert
4 comments so far
degoose
home | projects | blog
6589 posts in 1521 days
#1 posted 901 days ago
Thanks for the dedication and thanks for the inspiration.. this is indeed a lot of work… I know.. well done… looking forward to the end result…
Regards!
SPalm
4099 posts in 2048 days
#2 posted 900 days ago
Wowzie!! That is one heck of a glue up.
16×42 is really large. You will have state its weight when done. Like a baby.
Good job,
Steve
-- -- I'm no rocket surgeon
BertFlores58
1527 posts in 1088 days
#3 posted 900 days ago
Steve and to all readers…
Sorry for the misreading it… IT SHOULD BE 16 X 21 inches… I was thinking of the equivalent of 16 inches to be 42 cm… At any rate here is the latest update of it now. I am gluing the last edge where I would attach the border….
This was after the planing done… Ready for sanding.
One thing about this project… a beveled joint will allow let you gain a closed gap. Unlike the the straight joint you only depend on the clamping force…
-- Bert
BritBoxmaker
4003 posts in 1202 days
#4 posted 900 days ago
I am honoured, Bert. This is good challenge to take on, especially the glue up. I look forward to the next post, should be good.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
