Naphtha and Shop Cleanup
Blog entry by AnthonyC posted 07-02-2010 02:14 AM 1142 reads 0 times favorited 7 comments Add to Favorites Watch
I was getting the shipping gunk off of my OSS (had it two years and never used it) using some Naphtha and a rag.
It was going well, and I remembered hearing that Naphtha was good at cleaning planer rollers, so I figured it should be good for any of those foam grippy things we have around the shop. So a quick wipe of my jointer push blocks and my Grripper and they are all like new again. It was amazing how much extra grip was lost from a thin coating of dust.
So I’m leaving the Naphtha with the shop cleaning supplies instead of the finish thinners.
Just thought I’d share.
-- Amateur woodworker, professional mess-maker.
7 comments so far
View Lenny's profile
Lenny
1588 posts in 3403 days
#1 posted 07-02-2010 02:52 AM
Thanks for the tip Anthony. Do you know if Naphtha has different properties than de-natured alcohol?
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View AnthonyC's profile
AnthonyC
50 posts in 2782 days
#2 posted 07-02-2010 03:00 AM
I’m certain it does. I just don’t know what they are. :)
I used to clean sanding sponges with mineral spirits and tried denatured alcohol once. It disintegrated the sponge. So I’m not sure what plastics and rubbers react with what. I do know that naphtha seems to do well with the foam rubber, though.
Lenny
#3 posted 07-02-2010 03:03 AM
Hmm, I can see mineral spirits doing that but I wouldn’t expect de-natured alcohol to do so.
View 8iowa's profile
8iowa
1566 posts in 3637 days
#4 posted 07-02-2010 03:05 AM
Just be aware that naptha is highly flamable. Be careful how you dispose of the old rags. Years ago i worked at a school bus factory where we used naptha for cleaning. One day we had a small fire on our hands that could have had serious consequences.
It goes without saying that a “no smoking” rule is a good idea when working with flamable substances.
AnthonyC
#5 posted 07-02-2010 03:13 AM
Yeah, I was surprised too. This was a cheapo sanding sponge and I never tried denatured alcohol for it again. Might work with other ones, though. I suppose a test is in order the next time one of the sponges goes dull.
AnthonyC
#6 posted 07-02-2010 03:15 AM
No smoking in my shop, or house. Cigars on the back deck are as close as fire gets (and those are just 2/3x a year).
Is the Naphtha still flammable after evaporating (residue)? Or just as vapor/liquid?
View tyskkvinna's profile
tyskkvinna
1310 posts in 2862 days
#7 posted 07-02-2010 05:30 AM
I’ve had a shop rag soaked in naptha combust after several days (I assume it was fairly dry…?!)
It is a GREAT cleaner! The only thing I will use to clean my planer.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
