Workshop Cabinets and Helpers #1: Drill Press Table
Blog entry by AnthonyC posted 06-16-2010 06:28 PM 2850 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Workshop Cabinets and Helpers series Part 2: Melamine = sharp »
Just playing around with Sketchup and mocked up the drill press table I desperately need to build. MDF and Kreg T-track. Might add a dust port and hardwood border later.
Sketchup Drill Press Table
-- Amateur woodworker, professional mess-maker.
7 comments so far
117091 posts in 3577 days
#1 posted 06-16-2010 06:49 PM
Looks good
View PurpLev's profile
PurpLev
8535 posts in 3648 days
#2 posted 06-16-2010 07:02 PM
nice. thanks for the reminder that I need to revamp my table. I saw on one of the shopnotes that they incorporated the dust control into the replaceable center block – I’ll need to put it all into sketchup to see how best to utilize my current design and additional features I want …. this will be my 3rd DP table… quite amazing how this simple least used tool in the shop get so much attention from me.lol
View AnthonyC's profile
AnthonyC
50 posts in 2906 days
#3 posted 06-16-2010 07:40 PM
I need to cut a bunch of plugs for my hardwood floor rehab project coming up (red oak plugged with walnut—a few plugs came our or are damaged)—which is why this is such a priority.
The design is pretty specific to my Craftsman 1HP drill press. It has a semi-proprietary T slot on the metal deck for fixtures. I finally found some T nuts (big ones) that fit with 1/2” bolts. It will be a pain to line them all up, but since I drill 90%+ for woodworking, I imagine this fixture will stay up there almost all the time.
Hoping to build it this weekend out of scraps. Will post pics when I’m done.
View CampD's profile
CampD
1667 posts in 3486 days
#4 posted 06-16-2010 09:10 PM
Good design, I would definatly add a dust port
-- Doug...
View GregD's profile
GregD
788 posts in 3136 days
#5 posted 06-16-2010 09:14 PM
An alternative is to make the insert round rather than rectangular, so you can get a fresh surface by turning it a few degrees. I use 1/4” hardboard for my inserts, which I cut using a HF wing cutter. Also, I used the Incra T track that also provides a ruler – http://www.woodpeck.com/scaletrack.html
-- Greg D.
View Sarit's profile
Sarit
549 posts in 3139 days
#6 posted 06-16-2010 10:05 PM
Your thick fence is gonna eat up some valuable throat depth.
You can make the table deeper and cut a notch in the back of both it and the fence to allow space for the post. That should give you almost full depth.
View Rick's profile
Rick
9605 posts in 3033 days
#7 posted 06-17-2010 06:16 AM
Anthony:
Welcome to Lumber Jocks. I posted my Drill Press Table quite a while ago that might be of some help to you. There is also a Part 2 Posting that I believe corrects what GregD has correctly brought to your attention.
My Table Discards all the preconceived “Ideas” of what and how a Drill Press Table should look and Function. Mainly because the point at which the Drill is located, I referred to as “0” Point. Everthing else can Pivot around that point. Therefore a lot of “This Must run Parrallel with this. Metal Tracks are Needed, etc.” was discarded. As you will read it was a “Design as you Proceed” build.
HEY! One of my Favourite Expresssions is “Sacred Cows Make The Best Hamburgers.” ...LOL…
It turned out to be a “Multi Function” Drill Press Table, which is what I was aiming for. It’s stood the test of time and I’m very happy with it.
I also used a VERY Sophisticated Program during the “Design Build” Process …an HB Pencil WITH an Eraser, an Old Wooden 12” Ruler, and the Back of an 8×10 Piece of Paper that had something else on the Other Side….LOL.. ;-}
http://lumberjocks.com/projects/29446
Hope this is of some use to you.
Rick
-- LIFE is what happens when you're planning on doing Other Things!
