Music Stand III #2: Making the Legs
Blog entry by Alan Young posted 1043 days ago 1484 reads 2 times favorited 4 comments Add to Favorites Watch
« Part 1: New Design for a Music Stand Part 2 of Music Stand III series Part 3: Part III Gluing the tripod base »
A week or so ago I posted a thread on the beginnings of a new music stand design.
In this segment we’ll make the legs Here is the design:
The trip pod leg design calls for double loose tenon joinery to a triangular center block.
My drawing shows the general shape I want for the legs.
I could print out a scaled drawing of the profile, trace it to the stock and then cut it out but in this case I’m going to “free-hand” the profile. I like to save odd shaped pieces from other projects-these can yield interesting curves that can be used for drawing lines. In this case I’ll use several cutoff pieces and miscellaneous parts to draw my profile
I know the general shape I want- First I’ll mark the line where the curves end near the joint.!
Next I use this strip of plywood to mark the “height” of the foot’s pad.!
Then a line to mark the “length” of the pad.
Now I use the cutoff sections to mark the shape of the top curve
This walnut cutoff is used to mark the curve for the underside.
That radius was too tight- so I drew in a larger radius curve below the line.
The side profile is now ready to cut on the bandsaw.
Now to draw the profile for the top. I will make the footpad round using this brass pulley.
The width of my square is pleasing enough for the lines from the round pad to the end of the curve.
Using a thin strip ripped from some previous stock, I connect the round pad to the lines where the curves start.
Now it’s back to bandsaw to cut the top profile.
I’ll save these pieces for my curved cutoff bin. Looks like I might have a foot for another project down the road.
A bit of shaping and sanding then….
The feet are ready to be glued.
-Alan
4 comments so far
View Partridge's profile
Partridge
296 posts in 2125 days
#1 posted 1043 days ago
very cool design are you going to turn the stem
-- I get out in the shop when I can
View Alan Young's profile
Alan Young
108 posts in 1889 days
#2 posted 1043 days ago
Partridge-See segment 1 for the Center Post construction
http://lumberjocks.com/AlanY/blog/series/2941
View Gary's profile
Gary
3547 posts in 1602 days
#3 posted 1043 days ago
Nice work. I have really enjoyed watching your work
View sras's profile
sras
3244 posts in 1298 days
#4 posted 1043 days ago
Another great blog post! Thanks for sharing!
