Carved Coffee Table II #5: Gilding and Staining :The Finish
Blog entry by Alan Young posted 03-08-2010 06:52 PM 4094 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 4: Inserting Inlays in the Table Top Part 5 of Carved Coffee Table II series no next part
I finished the Coffee Table last week and took some pictures of it at my neighbor’s house yesterday afternoon. Here is one more set of pictures from the Shop. These show the finishing process- The final look and finish is no doubt not to everyone’s taste. The gilding wasn’t in my plan till way late in the process -even then I hemmed and hawed a lot over weather or not I should…I decided that I had the 1st coffee table with a single finish all around and that this was the one to set at full blast….:^) Here goes…......
The table is ready for the finish. I’ll employ a multi-step process involving these products.
Sealcoat de-waxed shellac to seal the inlays,
Super Brass Mica Powder and Clear Shellac for gilding,
A Red Mahogany Stain for a base coat stain on the base and the top,
A mixture of Tung Oil finish and General Finishes “Nutmeg” gel stain to tone the base only.
Polurethane for the top coat of entire piece.
The top will get a coat of red mahogany stain. I don’t want the light inlays to get stained so I start by sealing them with de-waxed shellac.
The next step is to gild the routed profile of the top and the carved elements of the base. The gilding solution is a mixture of Mica Powder and clear shellac. There isn’t a real formula here-it’s just a matter of how dense a gilded texture is desired. I want the gilding to sparkle but not totally cover the grain pattern.
I use an artists brush to apply the gilding to the edge. I want to cover the entire edge but not the top surface. If any gets on the top I just let it dry then scrape it off with a sharp chisel.
The edge is gilded, and the inlays are sealed.
The shellac/gilding solution drys within a half hour so while the top sets I move on to the carved elements.
The gilding on the base is finished.
Next- I brushed on the red mahogany stain then wiped it of quickly. I couldn’t take in between shots as I didn’t want the stain to set too deeply especially in the top.
The stain went on quite dark and covered the gilding and inlays but because of the shellac base on those elements, after wiping off the stain, a nice contrast is revealed.
After wiping off this first stain coat I let the table set over night. The next day I made a glaze out of Tung oil varnish and the gelstain. This was applied to the base only and there just to the non-gilded sections
I let this set over night and then the next day applied 2 coats of Gloss Polyurethane.
The Finished shots are on the Project Page. http://lumberjocks.com/projects/29190
Alan
2 comments so far
View David's profile
David
110 posts in 3249 days
#1 posted 03-08-2010 07:39 PM
cool blog and great work. thanks for sharing.
-- dcutter
View rwingnut's profile
rwingnut
9 posts in 2023 days
#2 posted 05-06-2013 07:38 PM
Beautiful job. I’m starting a project to make some picture frames that look like port holes and am trying to go for a metallic brass/bronze look to them. I am thinking about using the mica powder that you are using here. Did you put down anything before the shellac/mica powder? How translucent is the shellac/mica powder? I’ve read that you can adjust the shade/tint by using different colors underneath. Thanks for sharing.
