Carved Coffee Table II #2: Carving the legs and apron
Blog entry by Alan Young posted 02-15-2010 07:22 PM 4314 reads 2 times favorited 6 comments Add to Favorites Watch
« Part 1: Making the apron profile Part 2 of Carved Coffee Table II series Part 3: Leg-Apron Assembly and Glue -Up »
It’s time to turn my attention to shaping and carving the legs. Let’s look at the leg profile and design pattern from the first table:
The profile is a generously shaped cabriolet form.
The carved design is an acanthus leaf descending from a flowered shell figure. The leg profile narrows as the foot ends in a modified French Toe- a small carved scroll on “point”
The legs are still in fairly rough form.
Now I’ll shape the legs through the use of a spokeshave and various carving gouges, and files.
I finished the general shaping and carving of all four legs except for the Fleure de lis element that will be at the intersection of the top of the leg and the apron pieces.
I carved the Fleure de lis elements separately. I drew the design then cut the lines into the wood with various gouges.
From there it’s a matter of removing the background till the element is “raised”
Once each piece is defined I cut it from the stock and begin another.
Each element gets glued to the top of a leg. I’ll refine the carving further once the piece has set.
Next we’ll start carving the apron sections.
The end and side sections of the apron each have a descending block
From there the surface is filed and carved.
The profile of these sections is transferred to smaller pieces that are cut out and glued to the apron.
The design for the end apron sections has a repeat of the descending diamond in the center block.
A simple scroll bead detail runs from the center block around the apron ending in another scroll where the leg joins the apron.
Now I’ll continue the long process of refining the carved elements.
6 comments so far
View Jordan's profile
1400 posts in 3054 days
#1 posted 02-15-2010 10:33 PM
Very well done.
View Thomas Keefe's profile
Thomas Keefe
131 posts in 3338 days
#2 posted 02-15-2010 10:46 PM
This is a very informative post. Thanks. It is beautiful work.
View Dennisgrosen's profile
10880 posts in 3044 days
#3 posted 02-15-2010 11:09 PM
realy a great and informative blogs you have done so far
ceep them comming I´m looking forward to see the finished table
View sras's profile
4761 posts in 3058 days
#4 posted 02-16-2010 02:19 AM
This is an interesting story to follow. Already looking forward to the next entry.
View Chips's profile
199 posts in 3641 days
#5 posted 02-16-2010 03:25 AM
Great job
-- Make every day the best day of your life. Chips, Mississippi
View mtkate's profile
2049 posts in 3254 days
#6 posted 02-16-2010 03:33 AM
Uhm. Wow.
