Tool Cabinet Build #17: Saw Till and Tambours #3...
Blog entry by Airframer posted 04-11-2015 01:29 AM 1836 reads 1 time favorited 5 comments Add to Favorites Watch
« Part 16: Saw Till and Tambours Part Deux.. Part 17 of Tool Cabinet Build series Part 18: Saw Till and Tambours Finally Finished! »
A lot has happened since the last update just nothing that looks like much of anything has been done lol. I hate that kind of progress but it must be made to move forward.
Yesterday I was able to finish up cutting and fitting the track for the doors to ride in. Something that should be done before one of the panels is immovable… yeah.. that got a bit tricky but with the help of some brass stock and some juice cans I got it all glued up successfully.
After that was done I needed to figure out how to mirror that onto the back of the cabinet. My sons sidewalk chalk and some paper to the rescue!
Now I just had to cut that out and install it to the back and whalla.. tambour that actually opens and closes!
Then today after the boy left to visit Grandma I started putting the finish onto the inside of the saw till and making the stop piece for the doors.
First I painted the inside fo the back with some rattle can flat black. Why? Because it’s cheap ply and paint seems to work best in that application. The till is dark inside so black seems to work. I just mainly wanted to get something on it to prevent any moisture issues. I then hit the entire inside of the case side of the till with dark walnut danish oil.
Then while that was drying I started on the pull stop for the doors. I searched through my tub ‘o’ cutoffs to find something interesting and I came across a piece of rosewood that Terry sent me a while back. Why not right? I think I’ll just throw all the woods at this while I am at it lol.
I measured and cut two pieces off of it and finish planed them to size..
Then I cut the rabbet in the back so it can fit flush into the last strip of tambour.
Finally I shaped it up with a rasp and sand paper..
Then I knocked around some door pull Ideas and landed on a dowel inserted into some maple then turned that on the drill press till it was knob like in appearance..
Got it all glued up and tested some finishes..
Top to bottom is 3-2-1, Cherry Danish Oil and Dark Walnut Danish Oil. I decided on the 3-2-1. It just seemed to give it the most depth.
Annnnnnd this is where we have it for today.. one door with 3 coats of finish applied waiting on it’s mate to get finished then we can FINALLY attach the back and call the saw till done.
And a closeup of the stop block and knob..
That’s all for now. I hope to get the other door done tomorrow and this all one piece by the end of the day.
Thanks for reading!
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
5 comments so far
View johnstoneb's profile
2817 posts in 2106 days
#1 posted 04-11-2015 11:52 AM
That is looking good. Tambour doors is something I want to try sometime.
-- Bruce, Boise, ID
View terryR's profile
7098 posts in 2242 days
#2 posted 04-11-2015 01:31 PM
looking good, Eric! Glad the rosewood came in handy.
Those doors look like a ton of work, but I’ve always liked their appearance!
-- tr ...see one, do one, teach one...
View mafe's profile
11638 posts in 3022 days
#3 posted 04-11-2015 01:53 PM
Looks like it’s going to be a really cool till.
Best thoughts,
View Airframer's profile
3043 posts in 1886 days
#4 posted 04-11-2015 03:47 PM
Thanks Guys!
Terry – I still have a few more pieces that are waiting for their purpose (and one will be found soon I think).
The doors aren’t really that much work… I have made a lot of work out of them through simple ignorance of the easier methods lol. If I had a table saw and a routah this would have all been done in a day probably. But then I couldn’t bug you guys everyday blogging aout the same 2 doors as the day before lol.
View AnthonyReed's profile
9628 posts in 2373 days
#5 posted 04-13-2015 02:42 PM
It’s coming out great Eric.
-- ~Tony
