Hand Tool Journey #25: Repairing my Stanley #19 Block Plane No.1..
Blog entry by Airframer posted 01-01-2014 03:40 AM 2908 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 24: Carvers Vise #3 Part 25 of Hand Tool Journey series Part 26: Hand Tool Journey #25: Repairing my Stanley #19 Block Plane No.2.. »
This week I started restoring my what I thought was a Stanley #18 block plane that turned out to be a #19. That’s a good thing considering how hard to find they are and the fact I got this for under $20. Here is how it ended up..
The bad news is that while cleaning it up I needed to touch up the threads on the adjustable mouth. Luckily they are 1/4-20 so I got my tap out and started threading it in. I meat a bit of resistance and beyond my better judgement I decided to give it one more twist to see if it bottomed out or needed to cut new threads. Well it kept going right through the bottom of the plate!
So now I have an expensive plane with a hole in it.. piss.. what to do about this. I tried to find a replacement but this being a #19 the ones I found didn’t work. I pondered using JB Weld which would work fine but I have been warned that it can leave marks on your wood. That left clear epoxy. The only trouble with that is.. you could see the hole after the repair was finished.
So I continued scratching my brain for a solution when it hit me.. since it is 1/4-20 I could epoxy a 1/4-20 rod into the sole and after it all gets lapped flat should be just as strong and almost invisible to the surrounding area.
So here goes nothing..
I finished tapping the hole all the way through and inserted the filler screw and then assembled the plane to see how deep to thread it in.
Then I got out the epoxy
and marked a line on the screw.. added epoxy to it and re-threaded it back in. Again I re-assembled the plane to make sure it was where it should be then placed the plate in my “kiln” to cure overnight.
That is how it sits for now. Tomorrow I’ll cut it flush and start lapping the sole and fingers crossed this should work out.
Stay tuned for more!
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
10 comments so far
View docholladay's profile
docholladay
1287 posts in 3083 days
#1 posted 01-01-2014 03:52 AM
That repair should work fine. One other idea would have been to weld the rod in, but that also runs the risk of over heating and warping the part. Your solution is probably the best one.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View Handtooler's profile
Handtooler
1577 posts in 2156 days
#2 posted 01-01-2014 04:58 AM
Great brain in yo head!. I’m quite sure it’s gonna work juss fine. What will you use for lapping media and a surface. Keep the blog going. I’m gonna learn sumpin from this on the first day of our new year. HAPPY NEW YEAR all!YEAR ALL
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Don W's profile
Don W
18754 posts in 2591 days
#3 posted 01-01-2014 01:19 PM
Good recovery.
View Airframer's profile
Airframer
3043 posts in 1977 days
#4 posted 01-01-2014 01:35 PM
We shall see folks .. we shall see lol.
Handtooler – If I had a great brain in my head… this repair wouldn’t be necessary lol..
View theoldfart's profile
theoldfart
9740 posts in 2475 days
#5 posted 01-01-2014 01:44 PM
Eric, remembre to cut and file the correct side, buddy! ( it’s the one with the screw :0))
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Don W
#6 posted 01-01-2014 01:49 PM
You could have soldered to. No need to wait for it to cure. Ive done that on a infill somebody drill wrong was I wasn’t looking.
Airframer
#7 posted 01-01-2014 01:59 PM
Did you use regular plumbing solder and torch? I hadn’t even considered doing that!
Don W
#8 posted 01-01-2014 02:01 PM
I have used regular plumbing solder and silver solder. For what you were doing regular solder would have worked.
View terryR's profile
terryR
7168 posts in 2332 days
#9 posted 01-01-2014 02:31 PM
Nice restore, Eric.
You lucky dog with a SW 19! :)
-- tr ...see one, do one, teach one...
View AnthonyReed's profile
AnthonyReed
9755 posts in 2464 days
#10 posted 01-02-2014 04:55 PM
I bet breaking through the bottom of the plate elicited a string of profanity. Sorry it happened and glad to see you came up with a solid fix.
Thanks for sharing AF.
-- ~Tony
