Tool Cabinet Build #12: Aww Crap... Gonna need help hiding this mistake...
Blog entry by Airframer posted 11-14-2013 02:27 PM 2153 reads 0 times favorited 18 comments Add to Favorites Watch
« Part 11: Tonguing and Grooving The Night Away... Part 12 of Tool Cabinet Build series Part 13: Getting Back At It... »
Well, this morning I had an “Aww Piss” moment over my morning coffee.
I was sitting at the bench and decided to do a quick dry fit of the top to see where the secondary wall would land on it when I noticed I had made a HUGE error.
I rabbeted the wrong side of the top!
I had checked and re-checked before cutting it but somehow STILL ended up getting the wrong end. So now I have a rabbet joint along the front edge of the top panel.
My thinking on how to hide this is to add a curved decorative trim piece to that section.
Something like this but not exactly like it.. you get the idea..
The bad part is that this was my ugly rabbet so I will need to deal with cleaning that up to get a good joint out of it. Any other ideas?
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
18 comments so far
View AnthonyReed's profile
AnthonyReed
9668 posts in 2407 days
#1 posted 11-14-2013 02:38 PM
Bummer AF. I don’t know if the piece needs to be all that decorative. Maybe something as simple as a stopped chamfer w/lamb's tongue or something along those lines would be enough.
-- ~Tony
View WhoMe's profile
WhoMe
1564 posts in 3210 days
#2 posted 11-14-2013 02:42 PM
Imo, if you need a square edge, why not clean up the rabbet and insert another piece of poplar, plane and sand too the existing profile. Or use a contrasting hardwood to make it fancy.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View JayT's profile
JayT
5589 posts in 2178 days
#3 posted 11-14-2013 02:45 PM
Measure twice, cut once, curse thrice.
+1 on WhoMe’s idea of adding a strip of contrasting hardwood as an accent.
View Airframer's profile
Airframer
3043 posts in 1920 days
#4 posted 11-14-2013 02:49 PM
I had considered doing that but would loose the 2 pins. I could recut them but if it can be done without that I am all for it.
Tony.. I like the simpler idea. I might play around with my sash cutter on the 45 and see what I can come up with.
View sras's profile
sras
4790 posts in 3096 days
#5 posted 11-14-2013 03:31 PM
I like the decorative panel idea. Some of the most interesting features on my pieces have been the result of recovering from mistakes.
View JayT's profile
JayT
#6 posted 11-14-2013 03:34 PM
Why? I was just thinking you could inset a contrasting piece into the errant rabbet, not cut off any more.
View Mauricio's profile
Mauricio
7144 posts in 3119 days
#7 posted 11-14-2013 03:50 PM
Just glue some wood into the rabbet, once that’s dry plane it down about a 1/16”th. Glue another thin strip to the front to hide the interruption in the grain. Plain it flush to the other parts and Voila! Invisible…
Airframer
#8 posted 11-14-2013 04:16 PM
JayT – Ahh. I was confused. I see what you are saying now. I’ll play around with some wood and see how things look.
Maur – I like that idea too.. but now I am starting to like the trim piece idea lol. I’ll have a plan of some sort settled on by tonight I think.
View pintodeluxe's profile
pintodeluxe
5623 posts in 2780 days
#9 posted 11-14-2013 09:23 PM
I would fill it with the same wood type. You should be able to make a seamless repair.
Airframer
#10 posted 11-14-2013 11:27 PM
ARGGGGGG!!! I just checked the bottom panel and I DID IT ON THAT ONE TOO!!!!!
I give up.. gotta ponder this one for a bit..
View theoldfart's profile
theoldfart
9616 posts in 2418 days
#11 posted 11-14-2013 11:40 PM
It’s miller time!. Walk away, breathe, punch the wall, sacrifice a chicken, anything but try to work on that now. I drilled through the show face of a piece on Tuesday night. I’ll take care of it tomorrow. Your good at this so no worries you’ll come up with something and Stef will ‘dis ya and Red will cheer you on. Ah life is good ;0)
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Airframer
#12 posted 11-14-2013 11:49 PM
If I was still a drinker it would definitely be Miller Time but for now this is nagging me too much to step away from.
Gonna go look through my wood pile and see what I can come up with for patches….
View robswork's profile
robswork
5 posts in 3003 days
#13 posted 11-15-2013 01:56 AM
Couple thoughts, what about cutting the case down in depth and either adding a face frame or flush mounting a frame and panel back. I try to think of these moments as times to show my true skill. Old boss said anyone can do it when things go right, true craftsman make it work when things go astray. Let me know what you decide.
View tsangell's profile
tsangell
216 posts in 2660 days
#14 posted 11-15-2013 04:24 AM
I would cut it back and glue on a strip to rebuild the edge, then re-cut the front dovetail.
Airframer
#15 posted 11-15-2013 04:33 AM
tsangell – You know… After fiddling with it all night trying to get a filler piece fitted I think that is the route I will have to take.
More on this tomorrow..
showing 1 through 15 of 18 comments
