Hand Tool Journey #21: New Mallet No. 3.. Advise Needed..
Blog entry by Airframer posted 07-31-2013 07:49 PM 1963 reads 0 times favorited 14 comments Add to Favorites Watch
« Part 20: New Mallet No. 2 Part 21 of Hand Tool Journey series Part 22: Carvers Vise #1 »
I had a bunch of errands to run today which have kept me out of the shop. I just now had a chance to get out there to maybe get some shaping done on the handle when I noticed an issue with the mallet head.
It looks like some hairline separation of the glue joints have appeared since yesterday (or maybe earlier but I haven’t noticed them till just now). I am trying to figure out how to rectify this if it even needs rectifying.
Here are some pics of what I am talking about…
Top:
Bottom:
Now, since this portion will see a lot of impact force I imagine these need fixing if I expect this thing to last longer than a week I am just not sure how to proceed.
A couple options I am considering are bow tie’s on the top and bottom or placing some brass dowels into the 8 corners of the joints.. each of these options would be glued in place with 2 part epoxy instead of wood glue for added strength.
What would you do here (besides start over..)
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
14 comments so far
View chrisstef's profile
chrisstef
17167 posts in 2910 days
#1 posted 07-31-2013 07:54 PM
Id just drill some holes and jam some dowels in it. Or leave it as is. There’s probably enough glue in there to hold things together.
View theoldfart's profile
theoldfart
9409 posts in 2355 days
#2 posted 07-31-2013 08:02 PM
I’m w/stef. dowels and epoxy. Butterflys won’t hold as well given the impact it will have to bare, bear aw hell whatever!!
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View PurpLev's profile
PurpLev
8534 posts in 3552 days
#3 posted 07-31-2013 08:05 PM
if the estetics don’t bother you (it would some people – not me), then I’d say just use it, theres quite a bit of glue surface between those block, and I doubt anything will come apart. This is mostly on the edges due to the fact that this is where the wood dries fastest, it may even balance itself out at some point once you finish the piece and left it aclimate
View Airframer's profile
Airframer
3043 posts in 1857 days
#4 posted 07-31-2013 08:06 PM
Do you guys think it makes a difference if the dowels are wood or brass? I was thinking 8, 1/4” brass dowels sunk in here would add a bit more heft to it… or is that over kill lol..
theoldfart
#5 posted 07-31-2013 08:14 PM
Only issue I foresee would be wood expansion/shrinkage, with wooden dowels everything should move together. I think the metal may loosen over time.
Disclaimer: the above is conjecture only, not based on experience.
View FirehouseWoodworking's profile
704 posts in 3177 days
#6 posted 07-31-2013 08:16 PM
Eric,
Like the previous comments, I would just leave it and drive on. But your last message gives me the impression that you want to fix it.
If you are bent on fixing it, why not just cut through the glue line with a bandsaw? Then joint the two faces and re-glue. You may need to take a little off the opposite face to make the mallet even on both sides of the handle, but the jointer can take care of that for you.
Cheers!
-- Dave; Lansing, Kansas
Airframer
#7 posted 07-31-2013 08:20 PM
I don’t necessarily want to “Fix” it so much as keep it from getting worse and falling apart. If you guys feel that it is fine I’m good with leaving it be really.
PurpLev
#8 posted 07-31-2013 08:21 PM
overkill? in woodworking? what is that?
brass or wood dowels will not make a difference for wood movement as the grain is perpendicular either way. extra weight will only be a blessing in a – mallet. but It won’t add any additional strength to the glue line of the faces…
View Don W's profile
Don W
18604 posts in 2471 days
#9 posted 07-31-2013 08:21 PM
my vote would be use it.
theoldfart
#10 posted 07-31-2013 09:02 PM
Sounds like the group mind would bang away!
View Mauricio's profile
Mauricio
7139 posts in 3055 days
#11 posted 08-01-2013 06:54 PM
I’d think wood dowel would keep it together better than brass.
Airframer
#12 posted 08-01-2013 07:49 PM
What I ended up doing was wicking some CA glue into the cracks and clamping the tar out of it over night. They are nice and sealed up now so I am leaving it as is.
chrisstef
#13 posted 08-01-2013 07:51 PM
Smash something with it all ready will ya ;)
Airframer
#14 posted 08-01-2013 08:32 PM
Handle is in work still. I haven’t had much shop time in the last couple of days due to my work schedule but should be smashing stuff with it by this weekend.
