This has been a relatively slow week build wise. I had a series of 15 hour nights at work which kept me out of the shop for most of it.
I did, however, find a few minutes here and there to get some work done on the wagon vise for the bench. I need to knock this out so I can finish up the endcaps and get started on the leg vise and stretchers then finally assemble the darn thing.
I am fashioning this after the benchcrafted wagon vise which is a departure from my original plan of the Maguire vise but this one is simpler with fewer parts. Simpler means less chance of failure and that sits fine with me.
The first step was to determine where the threaded rod would go and then build everything around that. For this I simply printed out the build instructions for the BC vise and used their layout template to find the center of the rod. Then I drilled a 1” hole which I then used to mark the bench with.
Then I found a cherry cutoff and made a couple cuts on the MS to get it into shape as a push block..
Then I cut a notch in the wagon block to slip over the push block to get the center of gravity under the wagon block and not behind it.
I also cut a notch in the top of the push block which I forgot to take pics of but you will see in a minute anyway..
After that I drilled and carved out a nut sized hole for the 1” Acme nut to sit in… pretty proud of myself here.. this is as close to a perfect fit as I will ever see come out of this shop lol..
This is where it kinda slid downhill a bit. After a dry assembly I realized that I hadn’t taken the top thickness into account and my wagon block was WAY too short. So after what I thought were some careful measuring and number crunches I laminated a piece of cherry to the top so it will match the dog strip.. well Math makes me sad most the time and this was the case here.. I was still short so I decided (for Brandons sake ;) ) to make the wagon block a contrasting color from the dog strip. Thus explains the Padauk top layer on this. So here is my happy rainbow of a wagon block that now sits a bit proud of the top. That will allow me to plane it down perfectly flush once completely assembled.
Now that the block was done I can now use it to layout the mortise in the rod side of the vise.
Then out came the bit and brace to hog out as much material as possible since getting a chisel far enough in this will be difficult to say the least and my routah plane isn’t finished yet…
Then a dry assembly and this is where it sits now.
I still need to fit a block in the end of the mortise for the support bearing to fit into but first I need to fabricate the rails and base so I can get the alignment just right.
Turning this pile of steel into said rails and base is this weekends project :D
More to come. Thanks for reading!
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
10 comments so far
Buckethead
home | projects | blog
3194 posts in 1835 days
#1 posted 07-19-2013 12:18 PM
You’ve got drive!
Your build is coming along superbly. I will stay tuned to your vice build. I’m determined to get buy with purchasing only the lee valley screw for my wagon vice. Perhaps I can gain inspiration (aka steal ideas) from your build.
-- Support woodworking hand models. Buy me a sawstop.
Smitty_Cabinetshop
15280 posts in 2584 days
#2 posted 07-19-2013 12:26 PM
Eric, severe envy heading your way on this. So many wagon vices popping up, none of them on my bench!
Your build is looking great, even the rainbow block! :-) That steel doesn’t stand a chance, you got this. Great series of pics to go with the story, too.
theoldfart
9615 posts in 2417 days
#3 posted 07-19-2013 12:27 PM
Eric, your doin’ it! Can’t wait to see the finished vise. How did you make all those auger holes uniform depth? Count turns or depth stop?
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
CL810
3773 posts in 2954 days
#4 posted 07-19-2013 12:30 PM
Looks good AF!
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
waho6o9
8165 posts in 2543 days
#5 posted 07-19-2013 01:46 PM
Keep doing the good work Eric!
Airframer
3043 posts in 1919 days
#6 posted 07-19-2013 06:00 PM
Thanks folks. I am determined to finish this before the end of summer. This build has dragged on long enough lol.
Smitty – The thought of retrofitting a wagon vise to your bench makes me shudder but, of anyone could make it happen you could lol.
Kevin – I made a tape “flag” attached to the chuck that once at the correct depth it touched the square I have standing on end to keep the brace vertical.. you can almost see it in this pic..
terryR
7114 posts in 2274 days
#7 posted 07-19-2013 07:04 PM
Looks awesome, Eric. Thanks for sharing all the photos.
-- tr ...see one, do one, teach one...
theoldfart
#8 posted 07-19-2013 07:29 PM
Eric, thanks. BTW I spy a couple of Fender axes in the background.
Don W
18685 posts in 2533 days
#9 posted 07-19-2013 09:41 PM
I thought I posted an atta boy on this, but the “on the bench” shot must have blinded my senses. Either that of the internet swallowed the wrong post!
Airframer
#10 posted 07-19-2013 09:44 PM
HAH! ‘twas probably the glare from the top ‘o’ my head ;-)
Thanks Don!
