Hand Tool Journey #17: Shop Made Dovetail Layout Compass.. Part 5.. Bring Out Your Rasps!
Blog entry by Airframer posted 05-12-2013 05:18 PM 3073 reads 2 times favorited 12 comments Add to Favorites Watch
« Part 16: Shop Made Dovetail Layout Compass.. Part 4.. Almost There.. Part 17 of Hand Tool Journey series Part 18: Shop Made Dovetail Layout Compass.. Part 6.. Project Complete! »
Happy Mothers Day!
Just a quick update this morning. I had planned on keeping this update till I was finished but I couldn’t help myself. I just finished rough cutting the legs and I am pretty excited to say the least. It is a HUGE relief to have that part behind me because all that is left is a lot of rasping, filing and sanding to get the final shapes done and the “Possible Catastrophic Failure” meter is very low from this point on. However the shaping will have to wait till after I get back from the families house for Moms day stuff.
I was originally planning to just scan and print the design I drew up last night and use the 2 as templates but for whatever reason my scanner is refusing to scan. I then broke out the pattern makers tracing paper from the wifes sewing kit and traced the design onto another piece of paper and then went back over that with pencil.
Then it was just a matter of cutting them out and adhere them to the legs using spray adhesive.
After a few tense minutes at the band saw I now have 2 “close enough for government work” symmetrical legs ready for final shaping :D Thinking back I should have done a pre assembly before cutting just to double check that no integral parts would be lost in the design but a quick after assembly proved that nothing was lost and all functions wonderfully so I got lucky.
There you have it. I am probably about a day away from finishing at this point. The next update will be a Project post so stay tuned for that!
Thanks for following along on this silly little build of something that could be purchased for less than $10 but… where is the fun in that?
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
12 comments so far
View Mauricio's profile
Mauricio
7144 posts in 3207 days
#1 posted 05-12-2013 07:45 PM
Wow! That is friggin cool Eric! I’ve never seen anything like it, great job!
View Don W's profile
Don W
18791 posts in 2623 days
#2 posted 05-12-2013 09:31 PM
This guys got talent. Way cool!!
View Airframer's profile
Airframer
3043 posts in 2008 days
#3 posted 05-12-2013 09:54 PM
Thanks for the encouragement guys!
Shoot Don.. I’m just making it up as I go hoping like hell not to screw anything up lol.
A Sneak Peek…
Setting up to make dust..
Progress…. mmmm sexy…
Only a crap ton more rasping and sanding to go….
Could someone share the recipe for the 3-2-1 finish please? I’m thinking of going with that once this is all done.
Don W
#4 posted 05-12-2013 10:01 PM
Scott posted this elsewhere
3 parts paint thinner or mineral spirits which is the solvent to make it workable
2 parts poly which gives it durability and moisture protection
1 part BLO or tung oil which enhances the grain.
This the basic formula of commercial wipe on poly but much cheaper to make and you are not sure of the ingredients in stuff like Watco.
This isn’t an exact science and I lean heavier on the blo. I tend to like 1-1-1 better myself for most applications, especially tools, cause you can just wipe on more blo with better results.
Airframer
#5 posted 05-12-2013 10:02 PM
Sweet! Thanks Don!
Mauricio
#6 posted 05-13-2013 02:21 AM
the shaping is coming along great, that is going to really make it pop.
Airframer
#7 posted 05-14-2013 08:23 PM
More progress.. One down one more to go….
View PurpLev's profile
PurpLev
8539 posts in 3704 days
#8 posted 05-14-2013 08:27 PM
very unique.
nothing like a crap ton of rasping and sanding to make the day go by faster… enjoy !
Mauricio
#9 posted 05-14-2013 08:29 PM
Wow that’s cool!
Don W
#10 posted 05-14-2013 08:45 PM
that’s pretty cool.
Airframer
#11 posted 05-15-2013 12:08 AM
Thanks guys! I just finished sanding that leg up the grits from 220-2000 and then mixed up some 3-2-1 using the recipe you shared Don.. THAT STUFF IS AWESOME!!! The grain, color and everything just popped to life after I hit it with that stuff. Now I am assuming it goes on the same way as BLO? Wipe on and let soak a bit.. wipe off and do over till it no longer absorbs?
Don W
#12 posted 05-15-2013 12:14 AM
I like to wet sand the first coat or 2, but other than that, you are correct.
