Ok, so after tossing around some overly complex ideas and trying to reinvent the wheel I have finally settled on building a Hybrid Roubo style workbench. The design is tested and it works very well for what it does so why mess with success.
I plan on 2 vices. One wagon end vise and a leg vise. I had to do a lot of reading on the leg vise vs. a side vise to see what all the rage was about. I had never heard of a leg vise until a month ago when I discovered this website lol. After reading the pros and cons it does seem that the leg vise is the way to go.
I have poured over hundreds of pictures, plans and videos of different versions of this bench and really like the way the Benchcrafted vises operate with a hand wheel rather than a lever. It looks (and from reviews) seems like it would be easier to adjust and just looks nice. Yes I tossed in the looks card. If I am going to build something that will be around for a long while I can at least spend time making sure it looks good as well as functions well. Just me though.
I, however, have no intention of paying $400 for a hand wheel a 13” section of rod and a flange. I went to my local Fastenal store after work today and picked up a 6’ (yes I said 6 FEET!) peice of 1” #5 ACME threaded rod and 2 nuts to match. They only sell it in 6’ lengths or else I might have gone with less but this gives me plenty for 2 vises plus some and it cost less than $100 for the whole kit and caboodle.
This would be one HUGE vise if I used the whole piece!
Add to that I also found a couple hand wheels online at Reid Industrial Supply. I ordered one 8” cast iron hand wheel and 1 5” wheel. The larger of the 2 is for the leg and the smaller one is the end vise.
The 8” wheel was around $23 and the 5” was only $17 so total so far for the leg vise and end vise hardware I am out $130. I might sell off some of the threaded rod that I don’t use to recoup some costs or might hang onto it for later use (which there is always a later use right?).
Here are the wheels.. http://www.reidsupply.com/sku/BSW-8/
It is un drilled and I need to add a handle but that should be a matter of doing some drilling into cast iron. That shouldn’t be too hard (I know metal! Still learning wood!). And devise a method of coupling the rod to the crank. I’m heading out to look at plumbing fittings and such to see what I can come up with.
I’m still working out what kind of wood I plan to use and where to get it at so no saw dust just yet but hopefully sometime this weekend or next I can get started cutting wood.
As always suggestions are very welcome. Thanks for reading!
-- Eric - Why buy when you can build!?!
3 comments so far
grfrazee
home | projects | blog
217 posts in 305 days
#1 posted 106 days ago
Good looking with the cast iron wheels. I’ve had in mind to replace the lever-style handle on my tail vise with a wheel and didn’t really have any idea where to look.
Is there some trick to drilling through cast iron? I’ve drilled through steel a few times, but mostly I think I got my with large amounts of 3-in-1 oil as lubricant and not much knowledge. Any pointers would be appreciated.
If I hadn’t already made my moxon vise, I would probably offer to buy some of that threaded rod from you. Can’t wait to see how the build goes.
-- -=Pride is not a sin=-
Tugboater78
381 posts in 357 days
#2 posted 105 days ago
Welding is an option isnt it? Sounds like a plan though, ive bren meaning to check out fastenal for the same thing.. guess i will soon. Still some time before i can build a bench and the price for such materials overwhemed me as well and has put me off.. ill keep an eye out for your progress and maybe i can follow suit :)
-- Justin - the tugboat woodworker - https://www.facebook.com/justinb78
Airframer
418 posts in 118 days
#3 posted 105 days ago
@grfrazee – If you have drilled through steel than you can drill through cast iron. It is a bit softer than steel. The only thing you have to be careful of is cracking the iron. It has a tendency to crack if it gets too hot so just gooooooooo slowwwwwww and use copious amounts of lubricant only nipping about 5/16” at a time similar to using a Forstner bit. I plan to drill a 1/4” pilot hole and just gradually increase the bit size to just shave out the hole up to 1”. I still need to order some 1” bits though. Going to give the HF ones a try.
@Justin Bonnell – It is possible to weld cast iron but it is a lot harder to do. It just doesn’t like to take a weld very well due to the structure of the metal. I am still waiting on the wheels to arrive but once they do I will take a lot of pictures of the assembly process so you guys can do the same if you wanted at some point.
