This is for my wife as a first anniversary gift… the shade is rice paper. The wood will be walnut.
Finally got the hang of sketchup. turns out the key is to make everything into components otherwise it really really sucks! anyway, i made this design, inspired by some other folks’ lamp designs i found.
The joinery is essentially all lap joints of some sort or another. Frame members are all 3/8” or 1/4” other than the obviously thicker pieces, so relatively thin stuff for me. I’m wondering how I’m going to be able to plane/sand/scrape those. The top is removable for getting at the lightbulb. Here are some pics with and without the rice paper lampshade. I still have to figure out what sort of bulb i want in there and the proper fittings for it.
i can also send anyone the SKU file, but i dont have a way to post it here.
6 comments so far
DaveR
home | projects | blog
1527 posts in 617 days
posted 230 days ago
Hi Aaron.
It looks very nice. I would be interested in seeing the SU file if you want to send it. I’ll PM you with my e-mail address.
-- Until you spread your wings, you'll have no idea how far you can walk.
Todd A. Clippinger
5652 posts in 996 days
posted 230 days ago
I would recommend a fluorescent bulb. Otherwise you will only be able to spec out the use of a 60w or possibly only a 40w due to the heat build-up in the lamp.
You can get away with a higher wattage equivalent in the fluorescent because the bulbs do not generate nearly as much heat.
You will have to research the brands. Some put out an ugly, cold, greenish glow. Some have figured out how to create a warmer and more pleasing soft white glow.
spaids
460 posts in 590 days
posted 230 days ago
Do you think you might want to slip small panel pieces in between the four support columns to hide the cord? It would be a shame to have a visible cord screwing with the design of this lamp. I like this very much. I’m gonna mark this blog to watch so if you could please update back here when you build it so I can check out the finished lamp.
spaids
-- Wipe the blood stains from your blade before coming in.
Jojo
580 posts in 869 days
posted 229 days ago
It’s a nice design Aaron but I wouldn’t put shoji paper on top. Maybe, as Todd says, if using a compact fluorescent lamp but, even then, I’d leave a way for the heat to escape and not build up. Shoji paper is very delicate and could easily blacken or burn. I’m pretty sure that even a 40W lamp would burn the top in no time.
If you google ”andon” you’ll see that, traditionally, all of them have an open top for this exact reason.
-- Jojo, shopless in Kyoto ยท http://twitter.com/kagushokunin
AaronK
409 posts in 361 days
posted 228 days ago
you make an interesting point. perhaps i’ll leave the top unpapered, that should do well enough.
Derek Lyons
266 posts in 465 days
posted 209 days ago
Some fluorescents put out ugly light – but that can be filtered/changed by your choice of paper.
-- Derek, Bremerton WA --
